Problem with lower control arms
Old May 29, 2006 | 07:18 PM
Hiboost's Avatar
Hiboost
Default RE: Problem with lower control arms
I am in nightmare hell myself. My first new car: 02 WRX > I don't have a time to list the issues. Second new car: 06 GT > Tranny and rear end sounds like SHI*, Needs TSB for fuel pump, rattle at low rpms at the tranny, the driver's seat feels like its broke or lose, the bumper covers don't really meet the body, front right suspension sounds like its going to fall apart, etc. Oh well, guess I will have to buy a Camry next. I should have never left Toyotas... I am glad I didn't sell my 85 Supra.
I did get a good price on it with my Z-plan tho.
Old May 29, 2006 | 07:22 PM
W1ldcat's Avatar
W1ldcat
Sounds like if you didn't have bad luck, you'de have not luck at all..
Sorry to hear that..[]
Old May 29, 2006 | 11:59 PM
06GT4RAD's Avatar
06GT4RAD
BMR is a great company to deal with and i am certain they will help you with your problem. I had and issue with there upper Panhard Support hitting the mid pipe and they actually have gone back and redesigned the bar with more of a drop in it to solve my issue. I along with a few other people have had this issue while others have not. But BMR has been great to deal with thus far.
Richard
Old May 30, 2006 | 12:28 AM
mongrull006's Avatar
mongrull006
ORIGINAL: CrazyAl
ORIGINAL: mongrull006
aparently the axel is not centered from the factory. the panhard bar sets this position, not the LCAs
Ty
This is unlikely. We don't know the setup on Steve's car, there is no way we can be sure what the cause is yet.
If he's lowered his car without switching to an adjustable panhard, then it's possible it's just the Panhard bar. It is extremely unlikely for the panhard length to be wrong if the car is not lowered.
Also, if the lengths of the LCAs are not correct (or not the same) then it can skew the axle to one side or the other--in addition to, or in place of, the panhard bar.
actually it very likely, think about how the panhard works, as the suspension compresses the panhard pushes the axle to the side, ford probably set the axle to one side purposly to make up the difference when the suspension is compressed fully, making the axle centered then at 1/2 compression. this would also be a benifit to wheel clearence. besides, there have been several people who have measured theres and it is off center from the factory https://mustangforums.com/m_1402729/tm.htm
i would imagine the LCAs would have to have a significant difference in length in order for them to push the axle to one side making the wheel way off center in the wheel well.
Ty
Old May 30, 2006 | 12:55 AM
olym4gery's Avatar
olym4gery
If I had all those problems with a car.................. I would fix those first, instead fo trying to put mods on.
Old May 30, 2006 | 01:02 AM
Steven6095's Avatar
Steven6095
Mods were before and non related to the problem.
Old May 30, 2006 | 01:04 AM
Steven6095's Avatar
Steven6095
Hey guys and gals:
Tonight at a ball game I took a look at a stock 06 V6.
Walk up to the back right (wheel facing you) and look down. This car's wheel was also toeing in a bit. About as much as mine.
Maybe this is "normal". Maybe just something I am seeing due to the curvature of the vender, but my fiance also saw it. I never noticed it on mine until I put the LCAs on, but then again I never really looked.
Old May 30, 2006 | 10:31 AM
Steven6095's Avatar
Steven6095
Default RE: Problem with lower control arms (updated - yours too?)
**********bump************
I think I may be loosing my mind..[sm=dontgetit.gif]
Old May 30, 2006 | 10:54 AM
CrazyAl's Avatar
CrazyAl
Ty
That's a damn good point. Ford may well have purposely offset the axle. However, what I meant was that it should be the same before and after the LCA install, if he didn't lower the car or make any other mods. If he just switched to the BMR LCAs, then the "offset" of the rear axle should have been the same as it was before.
As well, we're not just talking about the offset (left and right) of the axle. In his original post, Steve says:
Looks like my back right is turned a little bit inward.
That implies that the axle is somehow "rotated", (from a bird's-eye perspective looking down at the car). This could happen easily of one control arm were longer than the other--for example if he had adjustable LCAs and they were set to different lengths. But, with 1-pc LCAs, if indeed this is going on with Steve's car, then something is REALLY wrong.
Old May 30, 2006 | 11:03 AM
Steven6095's Avatar
Steven6095
I am not worried about the wheels being off centered. The fact the back right wheel looks to be pointed inward toward the car has me concerned.
I am going to put the stock ones back on and see what happens then. Nothing against BMR but I want it back to stock and see what it looks like then.
