Eibach Pro Kit ALIGNMENT
Old Jun 17, 2006 | 12:32 AM
Black06stang's Avatar
Black06stang
Default Eibach Pro Kit ALIGNMENT
If I buy the eibach pro kit and install the kit myself, will I need both an alignment and the $30 camber bolts? Or will I need just one of them?
Old Jun 17, 2006 | 12:34 AM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: Eibach Pro Kit ALIGNMENT
Unfortunately you won't know until you have the car aligned. Only then will you be able to determin if you need the camber kit
Old Jun 17, 2006 | 12:42 AM
Black06stang
So do I definately have to have my car aligned? And about how much does it cost for an alignment? Or will installing the $30 camber bolts solve the problem?
Also, my rear is going to be off-center anyway, correct? So I wont need a rear panhard rod...right?
Old Jun 17, 2006 | 01:38 AM
Kaldar142's Avatar
Kaldar142
ah im confused now lol
before alls i thought you needed was the lowering kit and a panhard bar to re-adjust the alignment?[:@]
Old Jun 17, 2006 | 02:04 AM
Black06stang
Thats what im trying to find out.... I am this close to ordering the eibach pro kit but I want to know what else it required for this install.
Old Jun 17, 2006 | 02:07 AM
Black06stang
And if anyone knows a link to blackfoot's install quide please post it! I cant find it and I know it was a good writeup!
Old Jun 17, 2006 | 03:06 AM
Agleon's Avatar
Agleon
ORIGINAL: Black06stang
I too wanna know and how much it is for alignment.
Old Jun 17, 2006 | 09:50 PM
Kaldar142's Avatar
Kaldar142
bump
Old Jun 18, 2006 | 02:03 AM
grasshopper's Avatar
grasshopper
You will need the camber kit with the Pro-Kit. Most likely the alignment place will tell you your camber is off, charge you for the rest of the alignment and send you away with the same camber as before. Buy the camber kit now, and hand it to them when you drop the car off for alignment. Some shops will have them on hand and sell you a set, but I have yet to find one.
Old Jun 18, 2006 | 02:40 AM
fairlane292's Avatar
fairlane292
Consider only lowering rear. Roush or FRP rear coils. May not need adj panhard afterall; under an hour, easy install. ..nice level stance and you can add a chin spoiler later if you want and not worry about every driveway, speedbump.
