Doorsill, dash and rear seat removal
I have many questions so I'll start with these, does anyone know of any guides that will show me how to remove the doorsills, dash or rearseats?
The reason I need to do this is to set up a new audio system. I'd put it in the a/v section but I figure this would be benificial to others.
My next few questions have to do with amps. Have any of you run a power wire through the firewall? The only logical spot seems to be on the driver's side where a bunch of the wires pass through a rubber seal. How can I get to this easily, as it is below the wheel well I seems.
Second have any of you mounted an amp under the passenger seat? If so how did you mount it?
Lastly have any of you mounted an amp under the passenger seats? I assume there is no room so who has mounted one or two in the trunk. I'm trying to figure out how I'm going to secure all of this, preferably without drilling into any of the body sheetmetal.
radio removal http://www.myfilehut.com/userfiles/6...adioremove.pdf
Console removal http://www.myfilehut.com/userfiles/64040/console.pdf
Bunch of other good documents https://mustangforums.com/m_1019059/tm.htm
The back seats are super easy to remove, their are two tabs that you press in and then lift the seat nothing to it.
For the power wire through the firewall if you look in the passenger footwell their is a large grommet. to get to the backside of it you have to remove the wheel well cover and then you can see the grommet's back side i pushed a screwdriver through and then attached some small gueage wire to pull it through.
musnicki
Sep 23, 2015 07:11 AM
Sep 1, 2015 08:16 PM
