Trunk Lid Adjustment
Old Jul 7, 2006 | 11:54 PM
Dan64456's Avatar
Dan64456
Default Trunk Lid Adjustment
You know how you can adjust the gaps of the hood closing? (By turning the plastic or rubber ***** to adjust height, etc... )
I can't find the ones for the trunk.. Is it possible to even out the trunk closing gaps as well?
Old Jul 8, 2006 | 12:24 AM
Kaldar142's Avatar
Kaldar142
Default RE: Trunk Lid Adjustment
is your trunk out of alignment by any chance? mine is.
Old Jul 8, 2006 | 11:33 AM
Dan64456's Avatar
Dan64456
The passenger side closes a tad bit lower than the driver side... (That is in relation to the quarter panel...) If only there were a **** on where I just loosen, then it would even perfectly...
Old Jun 23, 2007 | 05:52 PM
jzinn's Avatar
jzinn
I've got the same problem, the driver's side of the trunk sits slightly lower than the passenger side. I reluctantly loosened all the mounting bolts holding the trunk hinge to the quarter panel hoping for some adjustability but either there is none, or it the paint is holding it in place. I didn't go much further because i was already pissed that the removing of the bolts stripped all the paint off of them.
where you ever able to find a solution? maybe i'll try again this weekend since the paint is already gone from the bolt heads and try and find some adjustment. I suppose that more people will see the trunk mis-alignment than will see the naked nuts, so to speak
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
