Tokico D-spec and Eibach pro spring kit
RE: Tokico D-spec and Eibach pro spring kit
BUT, as said above, where does stock fall??
Is the softest setting on the new shocks at least as soft as the old ones?? I know the whole point is to go stiffer. But usually shock companies advertise that their adjustable shocks go from 5% softer to X% stiffer than stock.
Looks nice, but it looks really low. How much of a drop is that??
Sometimes I think the stance on the GT is perfect stock up front and just a tad high in the rear. Other times I think the whole car is 3/4" too high.
Yeah, im also wondering the same thing. Ride quality is a huge factor imo and want to know if with the prokit and dspecs exactly how soft the softest setting is and how it compares so stock. It seems the handling and stiffer settings are amazing as people have said.
as for pics I think 06GT4rad's pics are better then mine and cleary shows the difference of before and after.
as for ride ricva05 gave a very good explanation as to what different setting feel like.
Now for drop kit claims 1.2 front and 1.4 rear
Here are my before//after measurements (please note exact spots may be hard to discribe but it's the difference you should be mst concerned with, and measurements are within 1/8" I wasn't trying to be exact I just wanted an idea of the drop)
Front spoiler 7 1/4" // 6" (below inside edge blinker, front edge of spoiler)
Front wheel lip 15 9/16 // 14 1/4" (center ofwheel hub to lip, this will not be affected by wheel size)
Rear wheel lip 16 5/8" // 14 11/16" (see about but rear wheel and lip)
Rear spoiler 12" // 10 1/4 (measured just inside of exhaust cut out)
Front of door 9 7/8" // 8 1/2" (front edge of door while closed)
Rear of door 10 5/16" // 8 3/4" (rear edge of door while closed)
I hope that helps 05SDI
ORIGINAL: BradInFl
side note for anyone lowering. In the rear shot from 06GT4RAD you can really see where an adjusable panhard bar is needed.
Also it is not as low as it looks. Yes it is low and you will need to be careful with steep inlcines. But it looks SO DAM GOOD!!
Yes that is a fact indeed. I had not adjusted mine yet since i wanted the suspension to settle a bit before adjusting it. It has been corrected though.
It was way off.
Richard
what does the adjustable panhard bar do? Adjust rear axel left / right? Sorry and please tell me what I'm looking for in 06GT4rad pic as they look REAL good to me.
05SDI
05SDI
ORIGINAL: 05SDI
05SDI
05SDI
Hope that helps...
ORIGINAL: 05SDI
I'm sure many have installed this same combo.
I took me 3.5 hours to do all 4 corners, with regular hand tools, out in my driveway by myself.
Looks Great!
Handles Amazing!
Very easy to tune!
After the first 100 miles I am very impressed. I was also very surprized how easy it was to install.
Great investment if you are looking for some cornering performance.
05SDI
Looks Great!
Handles Amazing!
Very easy to tune!
05SDI
Thanks...
Lets see you will need the following sockets and or wrenches;
10mm
15mm
18mm
and 13/16"
cressent wrench
jack stands
floor jack
2 straps
to compress the front springs I used two anchor points about 3' apart and to heavy duty ratchet straps. I wrapped the strap around the spring coils with each strap on opposite sides of the spring. So when I tightened the strap it would cause the spring to compress. Once the spring was comperssed I removed the nut and took off the part needed, then relaxed the straps one at a time. Took like 5 mins complete on the second front strut/spring combo to disassemble. Both front and rear are easy on a scale of one to ten I would say about a 2.5. I did that whole job by myself with out help and it wasn't too hard. 05SDI
10mm
15mm
18mm
and 13/16"
cressent wrench
jack stands
floor jack
2 straps
ORIGINAL: SweetGT
The adjustable panhard bar is used to re-center the rearend. When you lower your car the stock panhard bar actually forces the rearend outside of the car(one way or another), miss aligning all the rear suspension componets. Its generally not much but like a .5" or so...
Hope that helps...
ORIGINAL: 05SDI
05SDI
05SDI
Hope that helps...
