Tokico D-spec and Eibach pro spring kit
Earlier today I turned the struts down to 4 turns from full stiff.
My wife just went on a 100 mile trip and she said she noticed that the car rode almost like stock across expantion joints and bumps in the road. She was amazed that it took less then 4 mins and the ride could change that much. (it was set at 1.5 in the front and 2.5 in rear with 0 being most firm and 6 being softest) I have yet to drive it with the new settings so I can't comment on how it corners. BUT this is the main reason I went with these struts adjustability!!!! 05SDI
I just ordered my suspension mods:
- Tokico D-spec shocks
- Steeda sport springs
- Spohn ChrMoly adj. panhard bar -|
- Spohn ChrMoly adj. lower control arms -| ---Arrived today! Nice Bright Red parts
I hope to get things installed this weekend. I'll try to take install/before/after pics.
ORIGINAL: doc0075579
How much for the install of all of this?
Ditto...I'm doing it myself. I did my Honda with Teins, and that wasn't bad at all.
One question....what do I need for the Tokicos from the stock shocks/struts? I'd like to get those parts and have the ability to swap completely with the hassle of taking them back apart.
ORIGINAL: My05GT
You will need the white plastic block that fits inside the black dust boot and over the polished shaft of the strut. and you will need the black part of the strut spring set up/ This is actually a few pieces that make one. It is held onto the strut buy a single bolt on the shaft and it uses 4 bolts to mount the top of out strut/spring to our car. These peices are what holds the top of the spring. I know this was a VERY weak discription of the parts but that's the best I could do with out knowing the correct name. The parts that hold the top of the spring and bolt to the car are multiple pieces and have some sort of ballbearings so it can rotate (assume to be able to line up with the holes at the mounting pont of the car) these come off the original spring/strut combo as one piece.
Once you have it off you will understand exactly what I'm having such a difficult time trying to discribe!
05SDI
Great thread and thanks. That's just what I want to do and I have the Roush springs and need to buy the struts and shocks. I really like the way I can adjust the car for when I drive it to when my wife and I go for the Sunday drive.
I did hear from a couple of very reliable sources that the price of the Tokico D-spec are going up! I have heard different prices but the most expensive was like from $550 to over $800 for the exact same set of struts. Seems a lot of places are out of stock and back ordered!! Hmm Got to wonder what is going on. 05SDI
Mine are on back order from Brenspeed. Looks like the last week of July before they ship.
[IMG]local://upfiles/31319/DFE86B35AB114A73A0988C6A2C79A3AD.jpg[/IMG]
