HELP WITH HOOKING UP!
I HAVE 8PSI S/C, 3:73 GEARS. NEED HELP WITH GETTING TIRES TO HOOK UP ON LAUNCH. I READ THAT LOWER CONTROL ARMS WORK. WHAT ELSE DO I NEED? TRAILING ARMS? DO NOT WANT DRAGS, I DRIVE IT DAILY. SHOCKS? I WILL BE INSTALLING THE METHANOL/WATER INJECTION THAT WILL ADD APROX. 50 MORE HP. SO I REALLY NEED TO GET THE TIRES TO STICK. THANKS FOR ANY HELP!
Hello Blown...
You could always try americansingles.com... HA HA... just kidding...
I am sure you will get some help here, but you should also post in the Street/Strip section.
https://mustangforums.com/forumid_29/tt.htm
Also - - - Please type in "Proper Case". You will find some users annoyed at people who type with the cap lock key on!
Good luck!
Good luck!
I'm waiting to wear out these P-zeros so that my wife will submit to some sticky BFGs in something wider than the stock 235s.
In the meantime, I will work on launch RPMs and feathering the clutch till I get something acceptable (Of course, nothing but tires will fix mid-RPM issues.)
Well, I am N/A, but putting down some strong #'s, so here is what I did. It was a process, but this is the combo that has given me 1.69 60' times on street tires.
Steeda 3 point torque box braces
Steeda adjustable 3rd link set to a pinion angle of 3.8 degrees
"race" version adjustable LCA"s and panhard bar at stock length
BFG KDW2's at 25 to 28 lbs depending on track conditions
With this combo and a good launch, it sticks like the tires are covered in Velcro.
TURN OFF CAP LOCKS!!! J/K [8D]
Musiccity, like I said before, your times rock!
Are you footbraking an automatic with your launch?
With a stick it is hard to shock the drivetrain without going up in smoke or breaking something.
I had a 70 torino with a 460 and a C6 automatic. It pulled real strong with slicks doing the footbrake thing.
Your 3rd link set...is that the same as the upper control arm?
