Trunk Release Problem
Old Jul 14, 2006 | 06:56 PM
RainyDaye's Avatar
RainyDaye
Default Trunk Release Problem
I swear I've seen this before on this forum, but excuse me that I can't find it now...
The trunk on my 06 has never popped up after unlocking with the remote. I never thought too much of it until I was hanging out with a friend who also has a 06 mustang and his trunk poped right up after pressing his remote.
Is this somthing I can fix myself? Do I need to bring it to the dealership?
Thanks!
Old Jul 14, 2006 | 07:18 PM
W1ldcat's Avatar
W1ldcat
Default RE: Trunk Release Problem
Mine just clicks and doesn't come up on it's own..
Old Jul 14, 2006 | 07:23 PM
hottymustang's Avatar
hottymustang
My 05 did that. I took it to the dealer and the adjusted the latch and lubed it up a bit. Works perfectly since.
Old Jul 14, 2006 | 07:50 PM
RainyDaye's Avatar
RainyDaye
Maybe this is an '05 vs. '06 issue? Can I ask if anyone's '06 trunk pops up completely?
Old Jul 14, 2006 | 08:02 PM
stlsteed1's Avatar
stlsteed1
My 06 does not. Think about the weight of the trunk lid and it would also have to over come the
trunk lid supports (shocks). Your problem is normal.
Rt1Rebel's Avatar
Rt1Rebel
My '06 pops. As mentioned, sounds like a simple adjustment/lubrication to the release mechanism.
Old Jul 14, 2006 | 08:05 PM
Derf00's Avatar
Derf00
Gentleman's Relish
silicone lubricant on the trunk gasket, adjust the latch, and a bear for while you're sprayin it down
Old Jul 15, 2006 | 04:06 AM
Black06stang's Avatar
Black06stang
My 06 trunk just pops, it dosen't lift up. Should I take it to the dealer? Could they fix this?
Old Jul 15, 2006 | 10:37 AM
tdappleman's Avatar
tdappleman
My 06 pops with the remote - I agree with spraying the latch. Also take a look near the latch and make sure a spring is there (on the trunk lid section) - which is apparently what they are using to 'pop' it up.
Old Jul 15, 2006 | 11:44 AM
T.M.808's Avatar
T.M.808
my 05 works about 1/2 the time.Sometimes i push the button 4 or 5 times then it pops.I'll try the lube and adjust like mentioned above.Anything but the dreeded dealer..
