Disabling traction control?
Old Jul 14, 2006 | 08:06 PM
GTlust's Avatar
GTlust
I ♥ Acer
Default Disabling traction control?
I don't like the fact that traction control is on every time I start the car. I want to turn it on when I want it on. Is there anyway to change this?
Old Jul 14, 2006 | 08:17 PM
stlsteed1's Avatar
stlsteed1
Default RE: Disabling traction control?
A tuner will let you disable it
Old Jul 14, 2006 | 08:51 PM
blowngt's Avatar
blowngt
I ♥ Acer
Yeah, a tuner is a good bet cause reaching out and pushing a button is just too frigin' confusing.
Old Jul 14, 2006 | 09:30 PM
GTlust's Avatar
GTlust
I ♥ Acer
Is that an attempt at sarcasm?
ORIGINAL: blowngt
Old Jul 15, 2006 | 12:08 AM
Sonic Boom NH's Avatar
Sonic Boom NH
True, its very simple to just push the button. I think its a very stupid idea to have it turned off with a tuner because then you'll have to do much more then just push a simple easy button that takes less then 3 seconds...
Old Jul 15, 2006 | 01:00 AM
Orion_240's Avatar
Orion_240
aaahh, c'mon, don't you know it's the American way to spend 3-400 bucks to avoid having to press a button?
Old Jul 15, 2006 | 01:40 AM
05SDI's Avatar
05SDI
You could wire up a relay that would actully allow the switch to work exactly opposite as it does now.
Meaning each time you start the car the TCS would be defeated and by pressing the TCS button once after any start would be turning TCS back on.
Had something like this on my dodge ram and the OD tranny switch. Now that I think about it the Mustang could use two of these type of relays. 05SDI
Old Jul 15, 2006 | 02:45 PM
superiormirage's Avatar
superiormirage
LOL! Yeah, I am just not going there. =)
I do have a question about traction control: I've heard at higher HP people generally permantly disable TC to avoid engine damage. Is there any vailidy to this? And if so, what is the HP range?
Thanks!
Old Jul 15, 2006 | 05:14 PM
BlkonBlk's Avatar
BlkonBlk
How does the actual traction control work anyways? Does it cut off fuel when it senses wheel spin or does it apply the brakes somehow?
Old Jul 15, 2006 | 06:05 PM
QuickShortBus's Avatar
QuickShortBus
I ♥ Acer
ORIGINAL: superiormirage
Thanks!
It's not actually a HP thing, it's because with any type of forced induction, s/c, turbo or nitrous you are forcing extra air in the motor. When t/c kicks in it cuts fuel to the motor, at high RPM's and running lean when the fuel cuts out it can quickly blow a motor.
