clear coat???
Another good tip is to use two buckets, 1 w/ the soap & a clear rinse bucket. Use the rinse bucket to rinse the sponge/mitt/applicator before loading up in the soap bucket. This gets rid of the grit so your not sanding your paint.
Fairland, I am not an expert, but I have done alot of research since I started looking into getting my 06 Stang and you are dead on on. What I would like to add is to do the claybar process. Also when looking on buying a good quality car wash detergent, got Meguiar's CarWash shampoo/conditioner. Will not ever use anything else.
ORIGINAL: fairlane292
I recommend that you keep looking for a professional shop that does a lot of high end cars. You want an seasoned expert on a rotary buffer (not orbital). Once the detail shops gets the car back to what will be slightly better than OE, you can maintain. Keep in mind you can create swirl marks very easily by washing and by waxing (wax removal typically). few things to do to minimize creating swirl marks.
- get a screen plate for the bottom of your bucket.
- use quality car wash liquid soap
- use microfiber mit and don't rub hard; try to let the water and suds do the work.
- do not wash, dry or wax in circular motion (check on internet for technique; few schools of thought out there)
- after wash and thorough rinse, remove nozzle and sheet rinse (much less to dry)
- pull car in the garage and dry inside
- wax inside, never outside (unless you have no garage)
- do not let wax dry completely so haze is hardened and feels difficult to remove (major cause of marring)
- wax on and off with separate microfiber cloths
- I personally recommend BlackMagic Pro-Dry Absorbing Cloth. You lightly pull it over the surface w/o applying pressure
- wash dirtiest areas last (around wheelwells, rockers, rims, door jams); dry these areas last as well
I am not trying to tell you how to make your finish look terrific but giving you some info on how not to marr it; creating fine scratches and swirls. ...after the detail guy makes her look better than new. Good luck.
I haven't tried claybar yet and since my car is not a daily driver (garaged, never seen rain, won't see snow) it stays quite clean. Mainly now it's a few bugs at night. The thing that concerns me about claybar is that by design it picks up and retains particles; I'm just very logical by nature and with my black finish I don't want to be using anything that retains particles. One might think they are buried in a part of the clay that you are not making contact with the surface, but how do you know; you can't see these particles. I know two professional detailers and they don't use it; I just never asked them why not, but I will soon.
jwog666
Dec 27, 2021 08:09 PM
Oct 1, 2015 09:29 AM
