Dash Removal help!
Old Jul 27, 2006 | 06:23 PM
mdlesk's Avatar
mdlesk
Default Dash Removal help!
Okay, I need some help. I am wiring up a switch where I have the 3 empty panels on the dash (3 are usually occupied by "MyColor" - My car lacks this feature). How Do I get those 3 panels out. Also what is the best thing to use so that I can hook up an amp to my Shaker 500 and how hard is the install to do that. I might as well do everything at one time, while I have the dash off or at least apart. I can run the wires easy, it's just getting the front panels off that I need help with. Thank You!
Old Jul 27, 2006 | 07:14 PM
jaiasmit's Avatar
jaiasmit
Default RE: Dash Removal help!
I was able to just pry my fake 3 button panel off with a small flathead screwdriver. It's just held in by 4 little pressure tabs. Just take your time, and be careful not to scratch or dent anything along the way. As you start to pry it out, be sure to use your free hand to keep what you have out so far from popping back in.
Old Jul 27, 2006 | 11:43 PM
mdlesk's Avatar
mdlesk
Thanks...I finally got the switch on! Does anyone have any idea on hooking up an amp to the shaker 500?
Old Jul 28, 2006 | 02:00 AM
rex7010's Avatar
rex7010
ORIGINAL: mdlesk
sorry no.. but I do have 2 Alpine amps that I am no longer using.. if you don't have amps yet..
1 is 300 watts ( sub amp ) .. 1 is a 4-3-2 ( 4 at 50 watts .. 3 at 75 watts I think..?? , 2 at 150 watts )
I have all receipts and they look and sound brand new .. even though the are kind of old..
best of luck getting your amps in.. I am sure you will get it..!!!
Rex
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
