Gauges, Gauges, and more Gauges...
Okay so mine might be overkill cause I have a drag car and need to know what's going on with a lot of different things but for those of you just looking for options for a few gauges, here's some nifty places you may not have thought of...
(BTW - 2 you can't see in the piller and 2 more getting installed above the glove department when this photo was taken)
[IMG]local://upfiles/41573/0A92E439D9A046EA9FF0C619E06A7963.jpg[/IMG]
RE: Gauges, Gauges, and more Gauges...
ORIGINAL: blowngt
I really don't want to even know they are there - bling need not apply, but boost and intercooler temp are good things to know - particularly while tuning...
Thanks for the veritable collage of gauge ideas...
ORIGINAL: rfelger
WOW..thats alot!!...How hard is it to install the Oil pressure and water temp gauges?
Like I said, this is certainly overkill for a daily driver but mine is not your 'average' daily driver. My favorite spot is the panel above the glovebox. Just using standard anglers those look really trick inside the car.
I want to do the center pod thing with the three gauges. Any suggestions as to what gauges i should use?..I would like the white face to sorta match the car. At the same time it would be nice if they lit up blue at nite. Not sure if that type of combo is available?
Wow blowngt, did you have any clue how many people would be in need of your expert advice, maybe you should start charging!
I just wanted to add my $.02 by saying I think that is a gorgeous totally original and radically awesome interior and I definitely think you proved your point in justifying your need for all the gauges... and making every other owner on here drool thinking of an 18 psi blower PLUS NOS! WOW!
