Ford Plenum Cover Install Help Needed!
Old Aug 1, 2006 | 08:10 PM
alumacomp's Avatar
alumacomp
Default Ford Plenum Cover Install Help Needed!
I just received my Ford plenum cover. Based on previous threads, I also ordered the studs W710464-S437. I now read these are the wrong studs (they do appear far too long).
Questions:
1. My car was built in Feb/06...do I even need replacement studs?
2. If I need replacement studs, what is the right part number if W710464-S437 isn't it and do I require just the front two or all four?
Help please and thanks.
Old Aug 1, 2006 | 09:34 PM
Go Blue 48044's Avatar
Go Blue 48044
Default RE: Ford Plenum Cover Install Help Needed!
Maybe this will help.
Old Aug 1, 2006 | 09:38 PM
The long rider's Avatar
The long rider
My car was built the week of 1/9/06 and it has the correct studs, so I would bet you don't need them.
Old Aug 1, 2006 | 10:23 PM
05Retro's Avatar
05Retro
The Nuts are W520411-S437 and the Studs are W712289-S437, you need 2 each only for the front.
Old Aug 1, 2006 | 10:39 PM
alumacomp's Avatar
alumacomp
So do the sides just have the grommet slide over the stud with no bolting and then the original plastic cap holding the wire harness pops back on?
Old Aug 1, 2006 | 10:45 PM
05Retro's Avatar
05Retro
I'm not quite sure of that I haven't got mine yet. But I do remember something posted that did sound like that, it supposed to be a connected to a wire holder or something.
ORIGINAL: alumacomp
Old Aug 2, 2006 | 01:26 AM
alumacomp's Avatar
alumacomp
Yes the grommets on the sides just it over the existing studs and then the plastic caps pop back on top.
Front bolts were slightly too large for the grommets so I opened them up one more size with a drill. Then just used those bolts tightening them enough to ensure that the throttle body was snug to the plenum.
Sound OK?
Old Aug 2, 2006 | 02:18 AM
classj's Avatar
classj
I put mine on today. Took all of 10 minutes or so. I replaced the two front studs with the new ones, pulled off the two wire harness retainers in the back, fed the intake over the front studs, aligned the rear mounts and seated them. And put the wire harness retainers back on.
The cover cannot sit any lower so it cant go under the fuel rail bolts in the back, so I am assuming it just sits on top of the studs.
If you have to drill or modify anything, you have the wrong hardware.
Old Aug 2, 2006 | 03:46 AM
rex7010's Avatar
rex7010
ORIGINAL: classj
Do the wire harness retainers go on the new cover or underneath it.??. I am sure when I get mine it will be a no brainer.. lol
thanks in advance classj or anybody else..
Rex
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
inyadreems
Aug 21, 2015 09:10 AM
defarmer
Aug 13, 2015 06:40 AM
