Oil pressure
Old Aug 5, 2006 | 02:30 AM
rfelger's Avatar
rfelger
Default Oil pressure
where is the stock oil temp/ pressure sensor located?
Old Aug 5, 2006 | 02:51 AM
281GT's Avatar
281GT
Default RE: Oil pressure
Just above the oil filter. Driver's side, above the pan rail. The stock oil sender is simply a switch that closes the contacts in the presence of oil pressure above a certain point. It is not a proper pressure transducer. As a result the stock oil gauge does NOT indicate actual oil pressure. It only shows a reading of the pressure is above approx. 10 psi and reading is exactly the same regardless of the actual pressure. Basically it is an "idiot guage" as opposed to an "idiot light". If you want a real gauge the reads actual pressure you will need to go aftermarket.
Old Aug 5, 2006 | 03:03 AM
rfelger's Avatar
rfelger
Ok, where is a good place to install the oil/temp/pressure sending unit?
Old Aug 5, 2006 | 03:08 AM
281GT's Avatar
281GT
I removed the stock oil sender and intalled a brass T-fitting, then installed the stock oil sender in one side of the T and the aftermarket sender in the other side. Done.
Old Aug 5, 2006 | 03:18 AM
rfelger's Avatar
rfelger
That sounds good, but what about oil temp??
Old Aug 5, 2006 | 03:24 AM
281GT's Avatar
281GT
The only way to get an accurate reading for oil temperature is to remove the pan and have a bung welded into it someplace below the oil level for your oil temp sender. On one of my other vehicles I tried other methods but this was the only way to get a reliable oil temp reading.
Old Aug 5, 2006 | 03:27 AM
rfelger's Avatar
rfelger
I kinda figured that was the case, a friend of mine is using a sandwich adapter between the filter
Old Aug 5, 2006 | 03:29 AM
281GT's Avatar
281GT
The sandwich adaptor would also work. Any place where the oil circulates past the sender will get you an accurate reading. I had the engine apart so it wasn't much trouble to get the bung welded into the pan for me.
Old Aug 5, 2006 | 03:35 AM
rfelger's Avatar
rfelger
Cool, i might go that route then. thanks for your help!!
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
