vibrations
Old Aug 5, 2006 | 06:06 PM
bigboss's Avatar
bigboss
Default vibrations
hi guys, i own a 2006 GT (completely stock) with auto tranny and 3 months ago i had an accident which damaged my radiator & front suspension, . The car was perfect before the accident but now i'm getting a lot of rattles and vibrations. First, i got this popping sound from front suspension when i' turning. Then, i got this vibration and sound when i'm turning (i've read a lot and this problem seems to be the clutch packs). and today i noticed i have this very light vibration at around 1200 rpm's that makes the whole car resonate (like a droning exhaust). as i said, i've rad a lot and know that i need to change my clutch packs and also check bushings to solve the popping issue. my question is, if i don't adress this vibrations right away, will it hurt my car in the long run??
i am planning on getting some borla stingers axleback and i thought it made no sense to fix the drone if i'm going to get borlas. but then i thought that maybe this vibration might not be coming from the exhaust. any ideas?? motor mounts? tranny mounts??
are the moaning clutch packs hurting my car?? cause i can just put some music and forget about the noises if it is not a critical problem.
thanks a lot guys, i have found a lot of great info here, hope you can help me with these. thanks.
Old Aug 6, 2006 | 05:37 PM
bigboss's Avatar
bigboss
Default RE: vibrations
bump
Old Aug 6, 2006 | 06:24 PM
OMountainspring's Avatar
OMountainspring
the moaning clutch packs should be covered by warranty - my car is at the dealership now getting them replaced, but fwiw the tech said they hadn't done any harm to the car.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
