3.55 GEARS nolonger stndrd???
#21
RE: 3.55 GEARS no longer stndrd???
ORIGINAL: Tres Wright
No, not in the case of the V6. All the GT's whether manual or auto get limited slip rearends. The V6 get a smaller rearend than the GT and it is not limited slip. In 06 the Pony Package came with limited slip I think, but for 07 it is not part of the Pony Package, but is rather a stand-alone option (order code 552).
ORIGINAL: blackv6
do all manuals get a limited slip?!?!? i have a v6 stick and was going to get a limited slip diff, but dont want to-if i dont gotta!
do i really need a diff for my v6? i just wanted to swap out the gears. and later when i get the blower get the detroit locker.
please help!
#22
ORIGINAL: blackv6
what kind of diff came with the GT? T-lok? i heard they're only good for up to 250whp. is this true? i want to take my rear end apart once, mabye twice...
please help!
please help!
#23
Yes, the GTs all come with t-lock. The GT rearend is very strong and has handled upwards of 500 RWHP with no mod's. The V6 rearend is strong too (although not as big as the GT rear). If you go dig around on the V6 forum, there are several people there running power adders and they've had no problems with the stock rearend running in the 300 RWHP range. It is advisable to add t-lock to it if you're going to do that though (for traction if nothing else). You get much higher than 300 RWHP and you'll want to swap the whole rear.
ORIGINAL: blackv6
please help!
please help!
is a t-lok a t-lok? by that i mean a tlok for the 7.5 is the same as a t-lok for a 8.8 inch. it may be different part numbers, but is it the same materals, manufactured the same, etc?
#24
ORIGINAL: blackv6
i have heard of cars that slip discs when they hit 250rwhp.
ORIGINAL: blackv6
#25
ORIGINAL: blackv6
500 rwhp on a tlok?!?!? thats crazy. i have heard of cars that slip discs when they hit 250rwhp. when i add the blower i will be around that. i want something reliable and dont want to have to change only one tire every year...not to mention a diff every couple of years.
ORIGINAL: blackv6
please help!
please help!
#26
the 7.5 isnt to bad, the older 5.0 mustangs used it.
gm used a similar design to the 7.5 ford on all of their f-bodys, only 7.625.
even the lt-s and yes the ls-1 where backed by gms version.
#27
ORIGINAL: Nadelle
Ford used a 9" in the 5.0 until they changed to the 8.8" that we have now. The 7.5 was in the sixxers and the 4 bangers.
#30
http://bellsouthpwp.net/j/c/jcchaconjr/4v50faq.html
the ford 9-inch wasnt used since the early 70's and late sixties big block ford mustangs. dont have a link unfortunatly.
