Oil Pressure Sensor
RE: Oil Pressure Sensor
Ground out? You mean it's not screwed in?
ORIGINAL: rfelger
How do i ground out the stock oil pressure sensor? Im installing an after market gauge in its place with a "T" fitting for oil temp & Oil pressure
No, im installing an aftermarket gauge and i was going to disable the stock sensor but was told the computer needs that signal so im going to use a sandwich adapter bewteen the filter and block to install press/temp sensors.
HEY, before you use that adapter, you better look closely at the flow. If you block off the ports with a sender and pressure tap, you block oil flow. Or are you going to come out of the outlet through fittings and back to the inlet?
