warrenty work?
Old Aug 16, 2006 | 07:11 PM
05gtgreen's Avatar
05gtgreen
Default warrenty work?
I have to take my car in for warrenty on Friday. The engine light came on, thought i was do to the shaker scoop and plugging off the factory intake to the air box but apparetly it wasn't. To check that I disconnected my battery and removed the tape, put it all back together and still the same problem. The car runs fine, idles a little rough, but still drives fine. I have to take it 45km's to the dealership. When I drove it back to my parents house, I notice that every time I hit the gas peddle, it makes some kind of grinding noise now, not sure what that is from. My question is, I phoned ford and told them I was bringin it in cause the check engine light is on, should I just drive it there? I know it will make it, I am just scared that I might wreck more stuff on it, and they will give me crap for driving it. What should I do? I already put about 20km's on it since I connected the battery again. I should also mention that the car has no power at all when you press on the gas peddle.
Old Aug 16, 2006 | 07:26 PM
BigNasty06's Avatar
BigNasty06
Default RE: warrenty work?
Can't you pull the error code?
Old Aug 16, 2006 | 07:44 PM
lukoi66's Avatar
lukoi66
how do you pull the error code without a tuner like SCT2 or diablo?
Old Aug 16, 2006 | 07:50 PM
BigNasty06's Avatar
BigNasty06
ORIGINAL: lukoi66
Sorry... I SSUMED you could pull them in a similar fashion as my Durango.
I guess I'm even more happy that I purchased an SCT2.
Old Aug 16, 2006 | 07:52 PM
05gtgreen's Avatar
05gtgreen
I don't have a tune or anything like that, car is still stock. I just wondering if they are gonna say anything if I drive it there, but I guess I don't have any other choice, it better be covered what ever is wrong with it, 3rd time goin in for warrenty in the 6 months I owned it!
Old Aug 16, 2006 | 09:35 PM
BlackGTCoupe's Avatar
BlackGTCoupe
call 24hr roadside assistance, have them tow it for free. say car is unsafe to drive due to mechanical malfunctions, and unknown potential problems that could be caused. They will tow it for free to the closest dealer. Sound like a plan?
-Christian
06' Black GT coupe
Stuff
Old Aug 19, 2006 | 07:38 PM
05gtgreen's Avatar
05gtgreen
Well, took the car in and the engine light was from "banks one and two running lean". The codes thrown were P0171, P0174. So they reset the codes and took it for a drive and said it was fine. Well, I took the car for a drive and its not running right at all. It's got no mid range power at all, from idle it was fine and from 5000-6000rpm it ran perfect. It wouldn't idle down half the time (sit at 3000rpm). So, I took it back and they were tryin to blame it on my shaker scoop sayin that its gettin too much air and that voids my warrenty. We got in a pretty big arguement, then the service manager looked at the car and realized that I didn't change any of the computer stuff so I guess its covered again. But, when we went out to look at the car, there was a puddle of antifreeze laying under the car. Started it up, and it was idleing like crap, 400rpm. So.... they have no idea whats goin on with it, he said they would start at the mass air flow and go from there. I have a feeling I'm goin to be without the car for a while. Any ideas what could be wrong with this thing, what do the codes mean?
Old Aug 19, 2006 | 08:42 PM
BigNasty06's Avatar
BigNasty06
Well... Run it "lean" long enough, and you're going to smoke plugs, and probably damage some pistons. Then they can give you a new motor.
Old Aug 20, 2006 | 05:14 AM
05gtgreen's Avatar
05gtgreen
So, does that sound like the mass air flow sensor. That what I kinda think it is, but I'm not too familiar with these new fuel injected vehicles. This is exactly what my grand national was doin and the sensor was the problem with that. About this warrenty work, they charged me too look at the car cause the manager "assumed" I changed stuff on it when I didn't. Can I fight this somehow to get my money back, cause there is no way that shaker scoop should void my warrenty. How do I know if this damaged anything internally on the engine when I get it back.
Old Aug 20, 2006 | 05:15 AM
05gtgreen's Avatar
05gtgreen
