Gas pedal trick problem?
Old Sep 5, 2006 | 01:00 PM
moosestang's Avatar
moosestang
Default Gas pedal trick problem?
I read how to do the gas pedal/throttle lag adjustment and now it's pulsating when I step on it in 2nd gear. Did I do something wrong?
Old Sep 5, 2006 | 02:16 PM
svt93style's Avatar
svt93style
Default RE: Gas pedal trick problem?
Not sure, all I can think of is to redue it...mayber 3 times in a row.
What procedure did you use?
Old Sep 5, 2006 | 03:22 PM
moosestang's Avatar
moosestang
I did it three times in a row, steadily pressing down the gas pedal.
I'll try and do it again.
ORIGINAL: svt93style
Old Sep 5, 2006 | 07:06 PM
06GT4RAD's Avatar
06GT4RAD
ORIGINAL: moosestang
I did it three times in a row, steadily pressing down the brake pedal.
Why would you do that with the brake pedal? you are supose to do the gas pedal. Also you need to take about 3 seconds to full and then 3 seconds to off. Also make sure you never touch the pedal when the key is on unless you are doing the calibration.
Richard
Richard
Old Sep 5, 2006 | 07:14 PM
torch red's Avatar
torch red
Can you tell me again About how to do the calibration
Old Sep 5, 2006 | 07:16 PM
Tres Wright's Avatar
Tres Wright
The brake pedal? You're supposed to be pushing down the accelerator pedal for this trick!
EDIT- oops, Richard beat me to it
Old Sep 5, 2006 | 09:06 PM
Archion's Avatar
Archion
What is this trick you speak of, What is it supposed to improve, i did some googling on the subject and all that came back was sct and predator stuff, and nothing found using the search on the site.
Thanks,
Matt
Old Sep 5, 2006 | 09:50 PM
moosestang's Avatar
moosestang
What's all this brake pedal talk? You guys are so helpful.
At any rate I did it the first time by slowing pressing it down taking 3 seconds each way, but it's hard to steadily press the pedal for 3 seconds. The last time I did it quickly and it seemed better.
Old Sep 5, 2006 | 10:25 PM
06GT4RAD's Avatar
06GT4RAD
Ahahah you a funny guy. Problem is i have you qouted. Good Try though. I give you a A for effort.
Anyway to the others who are asking again. you can recalibrate the Throttle servo and it helps a little bit with the throttle lag. Get in the car and put the key in the ignition, then turn the key to the On position DO NOT start the car. Once you turn the key to the on position wait until the dinger stops and some of the warning lights go out. Then slowly about 3 seconds push the gas pedal to the floor and the release it also taking 3 seconds. Then tunr the key off and wait for about 15 seconds and then repeat the same procedure 3 more times.
Richard
Old Sep 5, 2006 | 10:45 PM
8URWS6's Avatar
8URWS6
I did the gas pedal trick and it made a world of difference. Unfortunately, it doesn't hold it for more than a day or so, and then, back to the 6 cylinder feeling GT. Such as life I suppose.
