STS or bust
RE: STS or bust
ORIGINAL: 1QuickShortBus
The numbers in my sig were at 9 psi on an otherwise bone stock car including the mufflers. They were also with the car already heat soaked and on a hot and humid day.
RE: STS or bust
Manual trans
No pulleys on a turbo it's exhaust driven not belt driven like a s/c. Boost can be changed with the wastegate spring, a manual boost controller (basically a device that limits how much boost the wastegate sees) by turning a **** or an electronic boost controller with a couple button presses.
RE: STS or bust
Ooo I see, so then its alot simpler to amp up boost on a turbo than it is on a sc... is it safe to run at different boosts, say at the track and on the street? Would it be too much of a pain to have to change them whenever you go to the track or would you need a retune or what?
RE: STS or bust
Listen to bus above. I've got too much low end on my KB. I have to leave the line at 1500 RPM just to keep going straight. The turbo lag is a ghost. That lag thing with turbos is a 1970's issue (consider a properly designed application). Even with an efficient screw blower, we are losing about 50HP turning the thing. That is where bus is making the extra HP.
I do like my power adder, but given the opportunity I would give more thought to the Powerhouse leaf blower.
RE: STS or bust
ORIGINAL: bl1nkage
RE: STS or bust
1QSB, how long have you had your turbo, also how long has PH had theirs and are they still running the stock bottom end?
i really like this kit, i am just not sure how long i would trust those numbers on a stock bottom end.
btw, what is your AF ratio and how much timing are you running?
Ty
Ty
RE: STS or bust
I have had my turbo for 6 months and 6k miles. PowerHouse has made well over 100 passes on their shop car at or above my power level. The advantage to a turbo is even though the numbers are higher the motor isn't working any harder than a s/c at the same boost level because the s/c is robbing ~50hp from the car.
RE: STS or bust
Look at it this way, would you be worried about a stock engine with a s/c at 400rwhp? It basically the same thing. In the end though it all comes down to the tune, how hard you turn the motor and the fuel that you feed it.
