Shifter loose? Help!
Old Sep 9, 2006 | 12:16 AM
06Vista's Avatar
06Vista
Default Shifter loose? Help!
Hey Guys,
I have notice that my car and a few others I sat in, the shifter is loose..i can spin it back and forth and also it seems to move a bit when I change gears. I sat in an 07' today and it was tight.. Anyone else have this issue? how did you fix it?
-Regards
Old Sep 9, 2006 | 02:34 AM
06Vista's Avatar
06Vista
Default RE: Shifter loose? Help!
I forgot to add a bit clunky, the 07' was real crisp, mine you can spin the shifter in nearly 360 degree circles. Anyone experince this?, Im sure it can be tightened is it the shift linkage? Thanks guys!
Old Sep 9, 2006 | 03:24 AM
05 Ricky's Avatar
05 Ricky
Yes, Mine did this when I broke my stock shifter, there are plastic bushing's in the stock shifter and when they let go that's all that holds the very top of the shifter handel in place. I know it sounds stupid but make sure your shift *** is tight. I upgraded to a Steeda Tri-ax and solved my problems.
Old Sep 9, 2006 | 03:37 AM
06Vista's Avatar
06Vista
Ricky, thanks for the reponse, I think I may have a visit with ford service in the near future, anyone else experince this oddity? the car only has 700 BABIED miles?
Old Sep 9, 2006 | 10:09 AM
redfireshaker06's Avatar
redfireshaker06
IF it's just the handle that's loose, pull the leather boot down a little and spin the **** to the right around one more turn or more if needed
Old Sep 9, 2006 | 01:23 PM
dmwtech's Avatar
dmwtech
My 06 GT was like this as well. Several on the lot were also like that. I thought it was some kind of funky shift **** at first and the service advisor said it's normal. I was like, you have to be kidding me. So I went home, grabbed the shift boot with my left hand and started turning the shift **** clockwise. I was able to turn it down about 12-13 turns before it was tight. It was that loose from the factory. Now it's perfect.
Old Sep 9, 2006 | 05:30 PM
06Vista's Avatar
06Vista
ORIGINAL: dmwtech
Ok Ill try that, I am quite shocked as well.
Old Sep 11, 2006 | 08:49 AM
paco_pony's Avatar
paco_pony
pull off the shifter boot and the dust shield. make sure the bolts holding the shifter arm to the piece coming out of the tranny are tight. this happened to me, not on the stocker but a few weeks after I got my Hurst installed.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
firehorse02
Nov 16, 2015 11:28 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
Sixer4Life
Sep 28, 2015 07:05 AM
