K Member Brace for '06 GT
I heard that installing a K memeber brace on my '06 GT would help with the transmission/drivetrain flexing that makes shifting problematic under load.
I found this one on-line. Does anyone have any comments on this type of brace and this brand (CHE) in particular? Some of the other brands either involved drilling or welding, and I was hoping to avoid any heavy tool use. I only drive the car on the street and usually not too hard :-)
http://powerhouse411.com/catalog/ind...products_id=16
Thanks,
Craig Kam
Thanks,
Craig Kam
RE: K Member Brace for '06 GT
I love mine. It solved my 2-3 shift problem and it is a VERY easy install. No drilling no welding, just a bolt on and go deal.
HERE is the post where I installed mine.
On another note; if you order one PM 1QuickShortBus 1st. He might be able to hook you up with a sweet deal.
You beat me! That's not fair as I had to find the post. So no more missed shifts yet?
ORIGINAL: Riven02
I BEAT YA!!!! [sm=icon_stickpoke.gif]
Fingers like lightning!!!!
LOL now you beat me!!!!
I have had no binding at all after the install. No missed shifts. The only negative is my shaker hood doesnt shake [:@]
This isnt going to make the shifter smooth it will just cure the binding that occurs under full throttle. So while I love mine dont expect it cure everything. This will just make the WOT shifts feel just like the low throttle shifts.
It never occured to me why they call it a shaker hood until this post. So could you really see a difference in the engine torquing? That would be cool to see the scoop shaking when you stomp on it.
ORIGINAL: Riven02
Well I had the toque limiters before the shaker so I dont have anything to compare it to but my shaker doesnt move much at all. Even under WOT I can only see it move if I am stairing right at it. Even then it is only a little bit. The torque limiters are definatly doing thier job.
The original shakers would shake like crazy at idle due to the agressive cam of the older cars.
try setting a low/unstable idle with your tuner.[sm=icon_rock.gif] I reset mine back to 750 after my CAI install, but I was afraid to set it lower even if it was just to see what it did. I'm sure it'd set a code.
ORIGINAL: Riven02
