Any 1 know where the SPEED SENSOR wire is so my Pioneer H/U can be installed correctly??
My new stereo shop is saying that I need a $200 piece in order for my Pioneer AVIC-D2 speed sensor to work. Has anyone tapped into their Vehicle Speed Sensor and would you be able to tell me where it is on a 2007 Mustang GT (Auto)???? Thanks!
RE: Any 1 know where the SPEED SENSOR wire is so my Pioneer H/U can be installed correctly??
Forgive me for being old and out of touch with the stereo scene, but what does the speed sensor do for your HU?
I think they say if you lose a satellite signal or some crap like that...it records how long you've driven so that when the signal comes back your trail will be tracked accordingly. I THINK! Some bull crap like!
the speed sensor wire works because on the pionner HU's they have a "vehicle info" screen which can tell you digitaly how fast your going, your acceleration and so on and so forth. The AVIC-N2 has a built in inertia sensor so I didnt even need to tap into that. Just a line to the e-brake. And that is a safety thing; you can't watch movies or enter a destination while driving.
ORIGINAL: Stoenr
Is it for speed sensitive volumn?
The shop I had my installed at doesn't hook this up in the new Mustangs because, they claim, it is actually computed within the spanish oak computer. You can install your head unit and not hook this up.
I've seen where some people have tapped into wires leading into the computer and I showed that to my installer and he said "yeah, that's not it"... so take that for what it is worth.
Your new stereo shop is blowing smoke up your ***.
You need to pop the cap on the top PCM plug and look for a wire that is dark blue with yellow tracer.... there you have it myfriend. THATS youre output shaft sensor. No longer VSS because the PCM reads the OSS and makes up its own VSS inside of the PCM, so its electronic. You can read it with a scan tool and bring up the VSS pid. But you cant actually tap into it for your GPS sensor wire and it will work fine. I have had my Kenwood navigation unit hooked up there for over a year with no issues. Have also passed the info to people with Pioneers, Eclipse, and Clarion. All have worked.
[IMG]local://upfiles/13513/50C99612FB394E608009F2513F4D1154.jpg[/IMG]
ORIGINAL: mAnYsTyLeS
What and where is the PCM PLUG? Thanks!
The PCM is the "computer" for your car. It is a wedge shaped box sitting on it's end between your power distribution box ( that thing that you probably thought was a fuse box ) and the engine. It has three harnesses running in to it. You want to remove the cover on the top plug to locate the dark blue with yellow tracer wire to hook your GPS sensor wire to.
*Disclaimer* If you F it up, it ain't my fault
