Roush rear springs
Old Sep 22, 2006 | 09:26 AM
  #21
CrazyHorse0217's Avatar
CrazyHorse0217
Default RE: Roush rear springs
Search this site using the words pinion angle, and you will get all the info you want.
Old Sep 22, 2006 | 11:57 AM
  #22
richmod's Avatar
richmod
ORIGINAL: CrazyHorse0217
Without going into a lot of detail, changing the shocks also changes the pinion gear and drive shaft angle...
But we're not talking about changing the shocks, just the springs.
Old Sep 22, 2006 | 12:06 PM
  #23
CrazyAl's Avatar
CrazyAl
Changing the SHOCKS does not change the pinion angle.
Changing the SPRINGS does change the pinion angle, as does any other mod that alters the ride height of the car.
Old Sep 22, 2006 | 01:55 PM
  #24
Stoenr's Avatar
Stoenr
These Crazy guys know what their talking about
Old Sep 22, 2006 | 04:57 PM
  #25
fairlane292's Avatar
fairlane292
If your ever looking for a set of "Front only" Eibach ProKit coils (brand new in box) let me know.
Old Sep 22, 2006 | 07:56 PM
  #26
CrazyHorse0217
My mistake........meant to say springs not shocks.
Old Oct 17, 2006 | 01:14 AM
  #27
praztek's Avatar
praztek
After installing the Roush rear springs, being told that the rear end is so far forward, that they were surprised to hear that its rides smoothly. Suggested items to add are lca relocation brackets for my spohn lca's, adj uca, and pan hard bar. Being told that it’s suggested to get the rear laser aligned as well. Anyone else go this route, just after installing the Roush rear springs only?
Thanks
Old Oct 17, 2006 | 01:34 AM
  #28
CrazyAl's Avatar
CrazyAl
Here was a good prior post about this but I can't seem to find it right now. Maybe you'll have better luck than I.
Anyway, when you lower the rear there are three side effects. Each may or may not be a concern to you, but they are all fixable:
1. The rear axle will become offset to one side. This is a "cosmetic" issue as far as I know. You can re-align it by installing an adjustable panhard bar. This might be what somebody meant when they said rear-end alignment--but you can ONLY adjust it (align it) with an aftermarket adjustable panhard bar. It doesn't require a laser alignment. You can do it yourself with a tape measure, some string, and a small weight.
2. The pinion angle changes. That can result in vibration, strange noises from the rear, and increased bearing wear. This is corrected by adjustable control arms in the rear (either upper OR lower, both are not needed). There are many threads about pinion angle adjustment.
3. The angle of the lower control arms change. This affects the instant center of the car. As-is, it can prevent the car from hooking up well on launch. LCA relocation brackets will address this.
Do you NEED to do all these things? No. Is it a good idea? Yes.
I suggest the adj. LCAs, adj. Panhard bar, and the LCA relocation brackets. You don't need a laser alignment and you don't need a new UCA.
Old Oct 17, 2006 | 01:46 AM
  #29
praztek's Avatar
praztek
Thanks !
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
TimeLord101
Sep 4, 2015 09:27 AM
Sep 1, 2015 08:16 PM
