clunk when accelerating after lowering?? (update)
Old Sep 25, 2006 | 02:08 PM
moosestang's Avatar
moosestang
Default clunk when accelerating after lowering?? (update)
Cruising in second gear I get a clunking noise when I step on the gas. Is this too much slack in the drive shaft? I never experienced this before lowering the car.
Old Sep 25, 2006 | 02:27 PM
moosestang's Avatar
moosestang
Default RE: clunk when accelerating after lowering??
06 gt by the way.
Old Sep 25, 2006 | 02:51 PM
|UCF|chron's Avatar
|UCF|chron
i hear a clunk whenever i go over bumps or deep dips inthe road after lowering my car.
Old Sep 25, 2006 | 03:00 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: moosestang
From what I've read there is an angle that has to be taken into account when you lower your car. It the angle of the driveshaft as it meet the rear u-joint that attaches to the differential. It's not slack that causes the clunk, but the angle of the shaft in relation to the differential.
Take it to a rear-end specialist (or back to the shop that installed it) and have them check the pinion angle (I think that's what it's called) of the shaft to pinion/differential.
Here's a link. It's for a lift in this case but the same geometry applies.
http://www.4xshaft.com/driveline101.html
Old Sep 25, 2006 | 03:39 PM
CrazyAl's Avatar
CrazyAl
Your pinion angle is off. You need to use adjustable LCAs when you lower your car to fix this. There's several threads about it over in the "handling" section.
Old Sep 25, 2006 | 03:49 PM
moosestang's Avatar
moosestang
I'm the one that started the thread in the handling section. I wasn't sure if the noise was specific to suspension or not.
ORIGINAL: CrazyAl
Old Sep 25, 2006 | 03:57 PM
moosestang's Avatar
moosestang
I think yours is the rear axle hitting the bumpstops. Try cutting the bumpstops in half and see if it helps. They are right about it not damaging anything, it's hard to damage the axle tube.
ORIGINAL: |UCF|chron
Old Sep 25, 2006 | 06:50 PM
05HOTROD's Avatar
05HOTROD
check your rear springs, and see if they are rubbing in the tunnel area. I added lca, uca and relocation brackets and my car began to make a clunk/rubbing sounds going in and out of driveways and sometimes just driving. check this thread out that I posted, maybe this will help someone. https://mustangforums.com/m_1996825/...tm.htm#1996825
Old Sep 25, 2006 | 07:57 PM
redfireshaker06's Avatar
redfireshaker06
Also, won't relocation brackets help the pinion angle?
Old Sep 25, 2006 | 08:47 PM
moosestang's Avatar
moosestang
Not unless they change the angle of the rear axle. I believe they only change the angle of the LCA's.
ORIGINAL: redfireshaker06
