CMCV delete
Old Nov 1, 2006 | 07:55 PM
LAK3RS's Avatar
LAK3RS
Default RE: CMCV delete
Are the CMC Plates pretty easy to in stall your self? I know you need to take the Intake Manifold off, and disconnect a some stuff, is that difficult at all? I've never done anything like that before...
Old Nov 1, 2006 | 10:20 PM
Rench's Avatar
Rench
Mine made it off the bench and went on the car tonight. I am using the Ford racing deletes with a Brenspeed 93 octane tune for this mod. Install took about an hour taking my time, install is easy, just pay attention to where everything goes. Did not disconnect any fuel lines, just pulled both fuel racks and put off to the side. Started the car after re-tune and idle was normal, about 1400 till warm up then dropped to 900/1000. Engine actually felt smoother, trust me, with the BMR K-member you notice smoother.
Took it out for a test run. Low end is better and top end is better. I have nothing negative to report from this mod. Definitely felt a seat of the pants improvement...............................I thought I may have made my last runs this year at the track but if I can get off work Friday I'll be at JDM day at Englishtown to test track performance.
Old Nov 1, 2006 | 11:55 PM
JGT's Avatar
JGT
Sounds like a good way to pick up an easy 10 HP....Any loss of gas mileage?
Old Nov 2, 2006 | 12:01 AM
Gig4Fun's Avatar
Gig4Fun
I plan to put mine in this weekend.
Can someone who has done it do this for me please? You must have a stick.
Let it slow down in 5th gear to 1000 rpm and then floor it. As it is now (pre CMCV delete) I can do this and it will pull from 1000 rpm at a steady rate building strength as it climbs.
I do not have any hickups or faultering at all. I would like to know if I can expect this after the install. Please do this and post up if you have the mod.
Thank you,
Russ
Old Nov 2, 2006 | 03:06 PM
scramblr's Avatar
scramblr
ORIGINAL: Gig4Fun
Thank you,
Russ
Why would you ever be at 1000 rpm in 5th? Just wondering...
Old Nov 2, 2006 | 08:22 PM
Gig4Fun's Avatar
Gig4Fun
ORIGINAL: scramblr
ORIGINAL: Gig4Fun
Thank you,
Russ
I wanted to see how much torque there was at that low of an rpm so a test could be devised to gauge against the CMCV delete. That is the "WHY". Surely it is not a way to drive.
Russ
Old Nov 2, 2006 | 08:49 PM
07GT's Avatar
07GT
ORIGINAL: Gig4Fun
ORIGINAL: scramblr
ORIGINAL: Gig4Fun
Thank you,
Russ
Russ
Sounds like a good test. I have never been below about 1250 rpm in 5th, and have never floored it at that rpm, but to test low end torque I would like to see someone with the mod try what you have suggested. If it bucks I would like to hear at what rpm it does work smoothly.
Old Nov 3, 2006 | 01:26 AM
scramblr's Avatar
scramblr
ORIGINAL: Gig4Fun
ORIGINAL: scramblr
ORIGINAL: Gig4Fun
Thank you,
Russ
Russ
LOL...Figured as much, just wanted to make sure you weren't a Drone junkie. [sm=smokin.gif]
Old Nov 3, 2006 | 07:28 PM
Gig4Fun's Avatar
Gig4Fun
ORIGINAL: Gig4Fun
ORIGINAL: scramblr
ORIGINAL: Gig4Fun
Thank you,
Russ
Russ
Can someone please do this for me? Please go out and post up how it runs!
Thanks,
Russ
Old Nov 3, 2006 | 09:14 PM
Rench's Avatar
Rench
OK Gig, the results are in..........
1000 RPM in fifth wll accelerate without bog.
I think I picked up about .05 to.07 on the track
Ran solid 12.6's today usually closer to 12.7's with an occasional 12.6, not anymore.
Ran in to heavy traffic alot today as well as normal driving plus some highway time, no issues at all..........
