Need some help
Old Oct 14, 2006 | 12:46 AM
skilz4u2nv's Avatar
skilz4u2nv
Default Need some help
I was driving today in the city and I noticed a problem.
At a red light or a stop sign I would stop completely. But when it was time to go I would shift into first and well drive like normal. Except this time as I was giving gas and releasing the clutch the car basically shook and i could almost feel the gears in the rear grind as if it didnt want to engage, but I would give it a lil more gas and it would be ok. All the other gears are fine with no problem. Its weird because it didnt happen everytime either maybe like 1 outta every 10 times. Almost feels like I forgot how to drive stick!! But I know thats not the case. Do I have a serious problem here???
Old Oct 14, 2006 | 02:39 PM
skilz4u2nv's Avatar
skilz4u2nv
Default RE: Need some help
no help?
Old Oct 14, 2006 | 04:51 PM
RCT06GT's Avatar
RCT06GT
Take it to the dealer.
Old Oct 14, 2006 | 05:50 PM
cekim's Avatar
cekim
ORIGINAL: RCT06GT
+1
could be a number of things - hard to diagnose with that info (or over the internet period)
Could be clutch flywheel - done any big burnouts laltely? That can screw up the surface of the flywheel/clutch such that until it wears down a bit, you get odd vibrations on engagement - that are more noticeable under the load of leaving from a stop.
Could be throttle body/fuel/vacuum leak -various TSBs there - though none that stutter when leving from a stop that I recall
Could be trans - TSB there to on the '05 if I recall regarding synchro's and metal in the fluid...
good luck - I'd get it to the dealer if still under warranty...
Old Oct 14, 2006 | 05:54 PM
Apoptosis's Avatar
Apoptosis
poptart tits
hmmm. Same thing is happening to me. It feels like it is coming from the front right wheel. It feels like it is slipping until I give a little more gas...
How long does it take to go to dealer [:@]
Old Oct 14, 2006 | 07:16 PM
Meph's Avatar
Meph
It could've been a low idle, and you didn't give it as much gas as previous times. Which gave the shaker effect.
