Leather shift knob
Old Oct 13, 2006 | 02:09 PM
Supernaut's Avatar
Supernaut
Default Leather shift ****
I have an 07 GT. The metal shift **** is burning hot in summer and now it's getting cold in fall. I want a leather one. Only one I've found is by Razo. Looks cool but what else is out there? Thanks.
[IMG]local://upfiles/45731/34965C4E830640FC9AE3BAE95D2ADD3D.jpg[/IMG]
Old Oct 13, 2006 | 03:02 PM
shaner's Avatar
shaner
Default RE: Leather shift ****
Can't you order one from Ford? I have an 07 and it came with the leather shifter.
There's a bit of metal (aluminum?) on the top that lists the order of the gears, but the rest is all leather.
Old Oct 13, 2006 | 10:08 PM
grabberorange1's Avatar
grabberorange1
I have an '07 also,and I don't know what you're talking about...mine is leather from factory, and it is does not get hot/cold...you have a pic of your shifter?
Old Oct 14, 2006 | 01:37 AM
mail906's Avatar
mail906
ORIGINAL: Supernaut
I have an 07 as well, and I took a pretty hard look at this issue.
The Mustang has a stock shifter shaft that is threaded in metric threads. Many if most aftermarket ***** are made to be a "universal mount" with set screws.
Thus, if you really focus on what you like - the **** you think really looks best - most likely it will be a universal mount ****.
The answer - in my view is this - you need to have an adapter made to be an intermediary component between the stock shifter shaft and the aftermarket ****. Let me quickly point out that I did not come up with this idea; I read about it concerning other non-Mustang vehicles.
Essentially you have an aluminum cylinder machined that will thread on the stock shaft. It should be made in outer circumference to accomodate the aftermarket ****. And then when the aftermarket **** is set up upon it - the set screws sink into a precision fit. And the result is not some sloppy setup.
At first glance, this all seems funky; complicated; and expensive. It is none of the above. More than a few members of this forum have offered to make me the cylinder referred to above. The cost is somewhere +/- $100 in a rough range. Thus for the cost of an aftermarket **** - $75 to $125 at list price - plus the cylinder - you are looking at $200 +/- for the shifter **** of your dreams. It seems pretty cheap to me given the fact that it is a component of the vehicle that you will experience firsthand each and every time you drive it.
In my case, I did all of this and puchased red/black shifter **** (a Grant product) before I took vehicle delivery. But in all candor, I have an 07 with the PTP and I like the feel of the stock ****. I just have not gotten around to it yet.
Below is a photo of the type of cylinder I am referring to.
PHOTO OF INTERMEDIARY ADAPTOR
And to all our machine shop members out there - if you have a lathe - you should run a batch of 25 of these cylinders or so, and sell them. It would be a win-win for everybody.
Old Oct 14, 2006 | 08:52 PM
Supernaut's Avatar
Supernaut
My 07 came with a metal shift ****. Probably part of an interior upgrade option (I have the leather dash, etc). In the summer sun, it got BURNING HOT. Now it's getting cold. I want leather.
Interesting idea about the adapter. I read this post about "sleeves" for fitting the **** to various shifters. Sounds like you might be right: http://www.mx5.net/products/swknobs/razo.html
Old Oct 14, 2006 | 08:54 PM
VnCist00's Avatar
VnCist00
www.hillbankmotorsports.com
-look for saleen shift ****
and it will come in leather
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
