Clear Corners, Need Some Input
Old Oct 28, 2006 | 06:42 PM
PistolPez73's Avatar
PistolPez73
Default Clear Corners, Need Some Input
First question. I just bought a set of clear corners for my 07 mustang GT. I was looking for some help on installing these and noticed some threads about weather these are legal or not. Does anyone no for sure if these things are legal? The ones I received are completely clear, no amber in them.
Second Question. I'm not sure how I go about replacing the facotry corners. They seem to be held in place with a tab at one end and two clips at the other. I can't seem to get either end free. Is there an easy way to get the factory corners out and get the new one in?
Old Oct 28, 2006 | 06:48 PM
Sherwood06GT's Avatar
Sherwood06GT
Default RE: Clear Corners, Need Some Input
They are legal if you put in bulbs that shine AMBER when on. You can do a google search for "stealth bulbs" and find several sources. They are a little tricky to remove. There are 2 tabs on the outside corners that need to be pushed in. once you have done that it will lift out. You'll need to pull the mud guard back to get to them from the side of the car. You won't be able to get at them from underneath unless you do that.
Old Oct 28, 2006 | 06:53 PM
PistolPez73
Thanks for the help Sherwood. I did notice the two tabs and figured the corners need to come off of those but I wasn't sure how. It looks like the tabs are made so they can't be pushed back through the holes. Should I just force them back through?
Old Oct 28, 2006 | 07:34 PM
lmmmmm's Avatar
lmmmmm
http://forums.bradbarnett.net/showthread.php?t=49230
Old Oct 28, 2006 | 07:46 PM
PistolPez73
lmmmmm, thanks for the link. That shows me exactly what I need to do.
Old Oct 28, 2006 | 07:59 PM
Herknav's Avatar
Herknav
go to stealthauto.com for the bulbs, they look great.
Old Oct 28, 2006 | 08:08 PM
PistolPez73
Thanks Herknav, I'm going to order the stealth bulbs right now. 60$ for the two sets is pretty expensive. I guess they do have a lifetime warrenty though. Thanks for the help.
Old Oct 28, 2006 | 11:12 PM
BigDave's Avatar
BigDave
Go here for the 3157 bulbs for $12/pair. Got them fast as well. Work great!
http://www.silverbulbs.com/
Dokilar
15
Oct 16, 2015 08:13 PM
b8checker
Oct 8, 2015 12:55 PM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
lmurf60
Sep 24, 2015 10:07 PM
