wire diagram needed
Old Oct 29, 2006 | 11:40 PM
donnyonee's Avatar
donnyonee
Default wire diagram needed
i need a wire diagram for the 05-06 mustang. what id like to know is where and what color, can i pick up the electric wire for the trunk. id like to put in a momentary switch in the glove compartment to open the trunk. i figure if i use the switched side of the brake pedal circuit thru a n.o. switch and connect it to the trunk circuit, itd be somewhat easy to have a in car switch only activated when the brake and button are pushed.
comments are certainly appreciated.
don
Old Oct 30, 2006 | 01:09 AM
Stroken97's Avatar
Stroken97
Default RE: wire diagram needed
this is posted somewhere and I am sure someone has the link. I think it is the white wirewith pink stripe in the loom by the fuse box, but search for the link first. Splice into the wire, ground the switch and your good to go. Cost at $3.
Old Oct 30, 2006 | 01:25 AM
Justastockmustang's Avatar
Justastockmustang
Diagrams
[IMG]local://upfiles/30856/752EE432BEF44E199E2D586E8A7CEF0F.jpg[/IMG]
[IMG]local://upfiles/30856/ECE4D561B4AC4CEB9C7D0BABA79A8E3B.jpg[/IMG]
Old Oct 31, 2006 | 03:33 AM
TinPony's Avatar
TinPony
Is this what you are trying to do?
https://mustangforums.com/m_1664438/tm.htm
importsmasher
Oct 9, 2015 04:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
Nurdyguy
Aug 21, 2015 10:23 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
defarmer
Aug 13, 2015 06:40 AM
