Hurst T-Handle Install
ORIGINAL: 05Retro
I fabricated a part from stainless steel to put under my Hurst shift ball. To me the T-handle looks awkward with the boot right up underneath it.
[IMG]local://upfiles/13839/593CE10EAFED4B4BA7F65E1EBB6274ED.jpg[/IMG]
ORIGINAL: grabberorange1
Hey what do think about this cover for the ugly rubber PB handle...here's a pic of mine, it would compliment your Hurst shifter nicely...
[IMG][ /image]
Its a little costly, but a major improvement over stock pos...
http://www.mgwltd.com/mustang2005_em...e_handle.shtml
[IMG][ /image]
I'm a Toolmaker so I designed and fabricated it myself. It is about 1-1/8 inches above the boot. Under the boot it looks like the stock **** looks. The inside hole is threaded about a 1/2 an inch at the top and the rest of the hole is drilled oversize so it sits down over the shift **** shaft so it doesn't sit to high. It also has 2 flats so you can lock the ball in position with a wrench. You can see one of the flats just under the ball.
[IMG]local://upfiles/13839/71810FEFA22D4D8899A11E20E49AE3A6.jpg[/IMG]
ORIGINAL: phatphil
Did you have it fabricated at a machine shop? How tall is it?
Shoot, I figure if he taps or single points threads the bottom of the adapter to fit over the existing threads and turns the other end of the adapter to the threads needed to accept the ball or t-handle it could be any length.
I agree, if you make it to high it will only weaken the strenght of the shift rod and also I think it would look terrible. Thanks for the offer to make you one but I'm not really interested. Sorry
ORIGINAL: nonstopred
that wont work our shift handle is only so high
ORIGINAL: 05Retro
Now that's slick!!!! I want one!!! You should market that bad boy!!!!
Sep 10, 2015 08:39 PM
