Sponsored by:
Sponsored by:
2007 Front Suspension Thunking Noise
Old 11-13-2010, 07:17 PM
  #2081
08blackoutstang
08blackoutstang's Avatar
Originally Posted by White81Z28
Hey I am new to Mustangs so forgive me if I ask a stupid question. I see this thread is 208 pages long and I cant read all of it. Anyway, on this page I saw TSB so will Ford fix this for us? I have an 06 and have this noise everytime I hit a bump.
welcome, and i have an appointment for tuesday to drop my car off for this problem, under warranty...
08blackoutstang is offline
Old 11-13-2010, 08:21 PM
  #2082
kc5mhb
kc5mhb's Avatar
Looks like its been solved. rls82959 confirmed the part number that fixes the clunking. I've long suspected the strut mount since I did the GT upgrade on my '07 convertible and the mount came apart while taking the struts out. It was a bit of a challenge to put all the ball bearings back in but I got it. That is when I noticed how cheaply made the whole assembly was. Glad to finally hear its been resolved.
kc5mhb is offline
Old 11-13-2010, 11:23 PM
  #2083
White81Z28
White81Z28's Avatar
So its the upper strut mount? Does anyone know how much this costs at the Dealer? How difficult would it be for a person who has not done any suspension work before to buy from dealer and put on myself?
White81Z28 is offline
Old 11-14-2010, 10:58 AM
  #2084
White81Z28
White81Z28's Avatar
Can anyone tell me what the large nut on top of the strut mount does? The one on the passenger side seems loose to me. The one on the drivers is tight.
Old 11-15-2010, 02:23 AM
  #2085
newjohnre
newjohnre's Avatar
I ordered my replacement (version "C"), $130-ish sent to Hawaii. I put them in today and so far so good. I definitely agree with kc5mhb that the old ones seem cheaply made. They fell apart when I pulled them away from the springs.
A couple of interesting things to note about doing the swap yourself. The part has all the old part numbers listed on the bottom and describes the stud type of each. The box is sold as a Kit but the dealer may tell you the price is "Each" (just make sure they don't sell you each side for $100. I ordered the Ford Racing 2011 SVT front strut mounts. The studs only align if the notch/arrow points outward towards the fender.
That is the nut that holds the strut mount pressed into the suspension spring. Make sure that it is tight while the spring is compressed. If the car is lowered it will show more threads than a stock model. To check that nut I found it helpful to push down on the fender in a pouncing fashion while hand twisting the nut. Over time it may work itself backwards and create a rattle and destroy the mounts bearings.
newjohnre is offline
Old 11-15-2010, 11:53 AM
  #2086
DarDan76
DarDan76's Avatar
Well I finally cured the problem with my 07 GT,I just bought a 2011 5.0 GT, Grabber Blue rocket ship. Not one rattle. And the girls like it. OK Sally lets go!!!!
DarDan76 is offline
Old 11-15-2010, 07:14 PM
  #2087
White81Z28
White81Z28's Avatar
Thanks newjohn, so if my top bolt is loose then I should tighten it up, right? I did not know if the would mess up the alignment or not. I can turn it pretty easily with a wrench. Drivers side is tight.
Old 11-17-2010, 02:30 AM
  #2088
newjohnre
newjohnre's Avatar
Yup. The actual tightness will be slightly different for each shock/spring setup. I have eight threads showing with my Tokico D-Specs and BMR springs. You may need to do this every so often if the nut (19 mm Deep-well) keeps backing off. I could try loctite I suppose but it give me an excuse to poke around under the hood.
Old 11-18-2010, 12:42 PM
  #2089
White81Z28
White81Z28's Avatar
Thanks man, I will get it tightened up. I started to the other day but did not know if it would mess anythiing up.
Old 11-18-2010, 09:19 PM
  #2090
White81Z28
White81Z28's Avatar
I tried to tighten it but the whole thing turned? I could not get the nut to turn without the little screw part turning also.
Quick Reply: 2007 Front Suspension Thunking Noise
