Headlight replacement
Old Nov 26, 2006 | 08:54 PM
OverlordvI's Avatar
OverlordvI
Default Headlight replacement
Hello all -
I have a 06 V6 vert and I'd like to replace the stock headlamp assembly with these projectors I picked up a few days ago:
http://www.americanmuscle.com/2005-p...ts-chrome.html
I've removed the three bolts and the plastic screw that keeps the assembly in place. Now, how the heck do I get it out of the car without breaking the plastic anchoring tab? Do I have to take the front bumper off (and if I do, how do I do that?)? Any tips / tricks would be much appreciated.
Thanks.
Sapan
Old Nov 27, 2006 | 11:02 AM
BeeStang's Avatar
BeeStang
Default RE: Headlight replacement
Yes, the front bumper cover has to come off. Otherwise you run the risk of breaking one of the mounting tabs or worst yet, scratching the bumper cover trying to get the light housing out and then trying to get the new one in. It's not that hard to remove the bumper cover. The first time I did it it took about an hour to remove and replace includiing light install.
Here is a view with mounting points noted; http://www.myfilehut.com/userfiles/6...t%20bumper.pdf
Old Nov 28, 2006 | 04:00 PM
bascho's Avatar
bascho
It's becoming more and more common to have to remove the front fascia when replacing a headlamp on modern cars. The reason is that headlamps now use a "catcher bracket" which helps to keep the fascia tight to the under side of the lamp eliminating a gap. People need to get used to this as a normal part of servicing the vehicle. Because of this necessity the OEM's have made removing the fascia far easier than in the past.
5.0muscle
Jan 11, 2016 01:17 PM
StalkerGT
Nov 28, 2015 03:09 PM
9550
Oct 26, 2015 05:01 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
