How wide would you say these tires are?
RE: How wide would you say these tires are?
Theyre actually not sticking out, theyre flush with te fender well, which is what makes me think theyre not 315s.... MAYBE 305 max, unless someone did one hell of a fit job.
They're actually the 235/45/17's on 17x7 rims off my 99 ford ranger. I photoshopped some extra rubber to see what it would look like. Sorry if I mislead anyone, I was just wondering how wide of tire it would take to get that look.
The offset should be the same or close to the 99-04 stangs.
I also like the angle of the pic, i stood back 50 feet and used a 200mm lens, worked like a charm.
They do stick out a little, maybe a 1/4 inch if that. They look fine in the rear, but I wouldn't want this offset in the front. I really want some wider tires in the back that are taller than stock by about 1 inch, I think it will look mean as hell.
ORIGINAL: bl1nkage
You know, I noticed a small photochop section on the left tire right at the inside edge of the fender but I didnt give it a second thought lol... I like the look of 295s but personally I want more.. unfortunately thats proving to be a bit harder than I thought.
ORIGINAL: moosestang
ORIGINAL: bl1nkage
