Cleaning engine bay.
Stoener where did you get that bracket to hold your filter for the JLT CAI? Is that the S&B filter that came with it? Mine is dirty and am not sure how to clean it other than using air it's getting bad.
Also please tell me where you purchased the stainless steel wire loom kit please! It looks awesome and would love to steal your idea.
nothsa, check pm.
Jersey, NO! BAD IDEA No high pressure should be used when cleaning, this goes for air or water! Get a cleaning kit.
http://jlttruecoldair.com/zencart/in...products_id=22
but even if you put it a few feet away??
ORIGINAL: Stoenr
nothsa, check pm.
nothsa, check pm.
ORIGINAL: GS2006
Stoenr - I noticed your strut brace fits nicely over the plenum cover. Who is the manufacturer of the brace?
But I just noticed they have a low clearance design available now! bastarts!!
https://www.strangedevelopment.com/S...ewCat&catId=11
ORIGINAL: Jerseyfury2
ORIGINAL: Stoenr
nothsa, check pm.
nothsa, check pm.
ENGINE
Engines are more efficient when they are clean because grease and dirt
buildup keep the engine warmer than normal. When washing:
• Take care when using a power washer to clean the engine. The
high-pressure fluid could penetrate the sealed parts and cause
damage.
• Do not spray a hot engine with cold water to avoid cracking the
engine block or other engine components.
• Spray Motorcraft Engine Shampoo and Degreaser (ZC-20) on all parts
that require cleaning and pressure rinse clean.
• Cover the highlighted areas to prevent water damage when cleaning
the engine.
