HELP! Immediate help needed.
Old Dec 15, 2006 | 01:39 AM
  #21
06GT4RAD's Avatar
06GT4RAD
Default RE: HELP! Immediate help needed.
OK hold on everyone. The item in question that popped out, did it come out of the backside of the front brake caliper? And if so when this happen did all the brake fluid come out with it? If this is the item that popped out then it is most likely the brake caliper piston and unless you are a very competent mechanic which to me sounds like not then you need to take that car in and most likely have the entire caliper replaced since you most likely damaged the o ring that help keeps the fluid in place behind the piston. Also if the entire ABS system has bleed out then it must be bleed and it has to be done with a IDS or other compatible ABS scan tool.
Note to all if you have this lack of knowledge when it comes to brakes please do myself and the rest of us you share the road with a favor and leave your brakes to a professional. Your life as well as the rest of us depend on your brakes working and if you do not know how to even bleed a brake system you have no business working on them to begin with.
Richard
Old Dec 15, 2006 | 01:40 AM
  #22
Jerseyfury2's Avatar
Jerseyfury2
he's talking about air in the lines, not bubbles in the brake fluid......he needs to build pressure back.
Old Dec 15, 2006 | 01:41 AM
  #23
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
He said he doesn't have ABS and he did not tell me what the "Black thing" is either?
Old Dec 15, 2006 | 01:42 AM
  #24
Jerseyfury2
lol sounds like ur in trouble man
ORIGINAL: 06GT4RAD
Note to all if you have this lack of knowledge when it comes to brake please do myself and the rest of us you share the road with and leave your brake to a professional. Your life as well as the rest of us depend on your brake working and if you do not know how to even bleed a brake system you have no business working on them to begin with.
Richard
Old Dec 15, 2006 | 01:43 AM
  #25
ST4NG's Avatar
ST4NG
ORIGINAL: 06GT4RAD
Richard
The black thing we speak of is inside the caliper itself. They are the parts that actually press on the brake pads.
It's in just fine, and we got the system pressurized... It seems to be working fine...
Now for the other side..... lol. I'll let you all know the end result.
Old Dec 15, 2006 | 01:45 AM
  #26
mygt500's Avatar
mygt500
im glad so far so good but be careful and test drive the car slowly!
Old Dec 15, 2006 | 01:47 AM
  #27
06GT4RAD's Avatar
06GT4RAD
Yeah that's the brake caliper piston which is exactly what i thought it was and it is very easy to knick the o-ring on them which can cause issues with brake performance and possible failure under load. I seriously suggest you take your car in and have the brake system completely checked out.
Richard
Old Dec 15, 2006 | 01:48 AM
  #28
mygt500's Avatar
mygt500
Sounds like good advice to me! Be careful!
Old Dec 15, 2006 | 02:33 AM
  #29
FredTT's Avatar
FredTT
ORIGINAL: 06GT4RAD
Richard
+1
You beat me too it. I would HIGHLY suggest you take your car to someone who knows what they are doing and have it looked at. When it comes to brakes, you shouldn't take any chances. If you are going to drive it to the mechanic (which I DON'T SUGGEST) make sure there is NO Traffic out and keep you hand on the eBrake. Any sign of trouble, get of the road ASAP and get it towed. Thats going to be cheaper then having to replace your entire front end because you hit a guardrail when your brakes fail.
~Fred
Old Dec 15, 2006 | 03:06 AM
  #30
ST4NG's Avatar
ST4NG
Well got everything finished. Both front brake pads have been installed...
It's working extremely well. The break piston that popped out seams to be performing just fine, I was able to reassemble it with the rubber covering. (A hammer help in the process)
I've taken the car out for a good test ride, trying it slowly around the neighborhood first, and when that checked out I tested it on the road. They are working flawlessly, I also took it on the freeway to test it under a heavy load. (The freeway here is empty right now.) It worked just fine.
Thanks for all your help guys! I'll take it to the local break place that will do a complete and detailed break inspection for free.
I freaked out when I took everything apart and wasnt sure if I was going to be able to do it or not, but it turned out to be easier than I was making it. The rear will come another day.
If your considering changing your break pads and have know nothing about cars, dont do it. However if you have a little knowledge it is simple once you understand what your doing. I feel confident I will be able to do it in the future when the time comes.
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
rocket22
Aug 28, 2015 07:08 PM
jesse1125
AmericanMuscle.com
Aug 26, 2015 02:34 PM
