Question about my new Hurst Shifter?
Old Jan 31, 2007 | 04:50 PM
Goody625's Avatar
Goody625
Default RE: Question about my new Hurst Shifter?
ORIGINAL: 06hoss
These guys are talking about putting locktite on the bolts that go through the stick...bottom of stick is black, top part of stick is chrome. The instructions only tell you to put loctite on the one bolt down on the shifter rail, but you need locktite on the handle bolts as well. I installed mine at first without loctite and the handle bolts came loose twice before I applied loctite AND torqued down some nuts on the ends of the bolts.
Absolutely no problems since.
none of mine have worked loose yet, and im hoping they will not......Love the shifter so far after a month!!
Old Jan 31, 2007 | 07:17 PM
Jurnymn's Avatar
Jurnymn
I suppose you guys used the blue and not the red loctite?
Old Jan 31, 2007 | 07:40 PM
Goldenpony's Avatar
Goldenpony
I thought about the Hurst, but knowing how good the MGW shifter was on the pre 2005 'Stangs, I want to see the new shifter from MGW for the S197 'Stangs. They're talking about a late Feb. release.
Old Jan 31, 2007 | 07:56 PM
06hoss's Avatar
06hoss
ORIGINAL: Jurnymn
No, I went ahead and used the red. The blue is only half (medium) strength. You can probably use either one though.
Old Jan 31, 2007 | 08:21 PM
Goody625's Avatar
Goody625
Blue here........kinda matched the car No problems yet.....
Old Jan 31, 2007 | 08:25 PM
DeStonn's Avatar
DeStonn
I have the shifter sitting in my office waiting to be installed, I would like to know if these shifters are smoother from second to third? Sometimes I miss third with the stock shifter.
Old Jan 31, 2007 | 08:42 PM
savagewater's Avatar
savagewater
ORIGINAL: DeStonn
I've had the shifter for a year now and all I can say is...Best bang for the buck as far as mods go! And take my word for it, you will have to apply yourself to miss third with that shifter.
Old Jan 31, 2007 | 08:51 PM
06hoss's Avatar
06hoss
ORIGINAL: DeStonn
The shifter has a shorter and notchy feel, but the shifter alone won't prevent you from missing third. What will help prevent you from missing third gear is either some torque limiters or stiffer motor mounts. Since the 05+ GTs have a remote mount shifter, it flexes from the torque of the motor/trans.
Torque limiter link: http://www.cheperformance.com/cartge...204&cid=15
BMR motor mount link: http://www.bmrfabrication.com/2005MustangMISC.htm
[IMG]local://upfiles/48298/1C2546DE91E240778050C2D76C39E9A5.jpg[/IMG]
Old Jan 31, 2007 | 09:12 PM
Goody625's Avatar
Goody625
ORIGINAL: 06hoss
ORIGINAL: DeStonn
+1......I missed 3rd a couple times right after I installed it....I really got on her the other night and hit 3rd perfectly....IMO its hit or miss (no pun intended) without the K-member and Torque limiter....I plan on adding those as the funds allow! I absolutely love the notchy short throws!
Heres a BAD picture of mine installed
[IMG][/IMG]
Old Jan 31, 2007 | 09:35 PM
DeStonn's Avatar
DeStonn
ORIGINAL: 06hoss
ORIGINAL: DeStonn
I have the motor mounts and they will be installed the same day as the shifter plus other mods
carid
Jul 8, 2016 09:55 AM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
firecoyote
Sep 27, 2015 02:37 PM
Sep 16, 2015 07:53 PM
Webster454
Sep 7, 2015 04:59 AM
