Pinion/suspension question
#21
RE: Pinion/suspension question
ORIGINAL: northy_polk
i followed just about everything up until this point. I have the Steeda HD Upper Strut mounts that allow for some camber adjustment [up to 1 degree], but I'm not sure what to do from here. I bought them because i was trying to get rid of a thunking noise, not for track performance. But now I'd like to take advantage of their slight adjustability. So. . . the alignment shop puts the camber bolts in there and gets the alignment set for street, but when i get to the autoX/road race, i can adjust them by giving them thedesired amount of "turns"to provide more camber [toe out?] that is more appropriate for the track. I realize it's not exactly this easy, but I hope I communicated what my question was!
Personally, I think you can run about -1.5 degrees of camber with 0 toe and get decent tire wear both on the street and track (with street tires). Track tires will require more camber.
I just had a good two hours or so of track time at Gingerman last week and came away with relatively minor left front outside tire wear, which is a pretty nice accomplishment for that track. The Goodyear F1 Supercar tires are amazingly sticky for a street tire, probably one of thebest "arrive and drive" tires out there.
Dave Kegel
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
