bleeding clutch
Old Jul 11, 2007 | 10:53 AM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: bleeding clutch
ORIGINAL: partsbill
[ol][*]Make sure all hydraulic lines are correctly seated. Make sure all bleed screws are tightened to specification.[*]Tighten to 8 Nm (71 lb-in).
[ul][/ul][/ol][*]Make sure the clutch pedal is in the most upward position.
[ol][/ol][*]Check the fluid level of the brake/clutch reservoir. Fill the reservoir with the specified fluid to the MAX mark.
[ol][/ol][*]Using a suitable bleeder kit and a vacuum pump, install the rubber stopper in the reservoir opening. Make sure the rubber stopper has a tight fit.[*]Alternate method: use a 50 mm (1.96 in) rubber stopper with an 8 mm (0.31 in) pipe inserted through the rubber stopper.
[ul][/ul]
[ol][/ol][*]Holding the rubber stopper in place, operate the vacuum pump to 15-20 inches of vacuum. Hold the vacuum for one minute, then quickly relieve the vacuum. Remove the special tools.
[ol][/ol][*]Check the fluid level of the reservoir. Fill the reservoir with the specified fluid to the MAX mark. Install the reservoir cap.
[ol][/ol][*]Depress and release the clutch pedal 10 to 12 times or until clutch pedal effort is consistent and positive at top of clutch pedal travel.
[ol][/ol][*]Repeat Steps 4 through 6 two additional times or until clutch pedal effort is consistent and positive at top of clutch pedal travel.
[ol][/ol][*]Install the reservoir cap.
[ol][/ol][*]Check the clutch pedal reserve. Test the clutch system for normal operation.
[ol][/ol]
The non tool method is to find a steep hill of at least 45 degrees and point the
stang uphill and with the engine off, pump that clutch pedal slowly. Just a keep
on a pumpin untill you get tired. Or go to the stealership and let them use their
special tools to do it.
Old Jul 11, 2007 | 02:09 PM
sweetstang77's Avatar
sweetstang77
who ever has an aftermarket clutch please answer this.. When you let your clutch out where does it grab, mine is at the end of the pedal????
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
