bmr susoension
RE: bmr susoension
I am running mostly BMR parts in my suspension, and I have installed many other BMR parts for other people. In my opinion, the BMR products are the best you can get, with only one exception: I think Steeda's K-member brace is better than BMRs. Other than that, BMR is the cream of the crop.
As far as LCAs and panhard go, you won't find anything better.
RE: bmr susoension
I have the BMR Tubular K Member and A-Arm as well as the Chrome Moly Adj Panhard bar sitting in my apartment right now. When I get back next week I need to drive up to BMR to pick up the Level 3 rear control arm package. The quality of the parts is just amazing. And I really like the new silver vein color.
Oh I also have the sway bar relocation brackets.
RE: bmr susoension
ORIGINAL: callahan
Must be "Tard" day on the Mustang Forums.
Richard
RE: bmr susoension
Install is not that hard, but you need to make sure that if you have adjustable ones that they properly set up the pinion angle and the panhard bar length.
I'm not sure what it would cost from a shop just for those Items. But I do have a local shop to me that has given me some great prices for work so far. I'm having them do my new suspension and they quoted me $550 to install:
Tubular K member, Tubular A-Arms, Adj UCA with mount, Adj LCA's, Adj PHB, Sway bar Relocation bracket, as well as my Coil Over kit which will be a front Coil-over with Adj Koni's and CC plates and then Adj Koni's in the rear with springs and height adjustable perch.
I'm also going to see what they want to do my Line Lock install and I might add in Billet strut tower braces at the same time.
All I will have left to do suspension wise is Sway bars and stiffen things up with Welding in subframes, TQ Boxes and seams..
