Saleen Supercharger Installation Questions
I am approximately 95% complete with installing my Saleen supercharger and upgrade kit and I have a few question. I've been lurking on this board for over a year now and have learned a lot about the Saleen install on this board. As a result of this research my install has been somewhat uneventful (knock on wood). Anyway, my questions are;
1) How do you install the water pump timer. The double sided tape does not stick to the timer, even after I roughed up the surface. Any suggestions?
2) The instructions say that when filling the car and S/C coolant systems, you must pressurize thereservoirswith a coolant pressurization system. Is this step really necessary or can I just fill the systems normally?
By the way, I took a LOT of photographs (Approx. 400) during the installation process if anyone needs these. They are referenced by Instructions Manual page and step number.
Thanks in advance.
Thanks in advance.
RE: Saleen Supercharger Installation Questions
It drove me nuts, nothing sticks to the timer!
I had to wrap it all the way around w/ clear packing tape, than the double stick would work.
As far as the coolant pump res. I filled it to the top while the pump was running, took a few laps around the block and refilled.
I checked it a week later and had to add alittle to top it off.
I assume all the air is out of the system now!
Have you driven her yet?
It's a kick in the pants!
I wish I had a dyno around here to check the numbers!
I hope this helps.
Rick
I hope this helps.
Rick
+1 to the velcro. That is what I used.
As for the pressurization. That is to test for leaks. No, it isn't necessary. But you had better be extremely confident in your install.
ORIGINAL: jerseystang07
Definately want to see some pictures of the final product!
HeyJerseystang07, is the Mustang stripes on your doors paint or stickers? I noticed mine are just stickers... thanks.
Thanks for the comments. Looks like I will go the Velcro route.
I am very comfotable with the plumbing I did on the hoses so I will not perform the pressurization. I used the worm gear clamps and they are very tight.
Thanks again for your suggestions.
ORIGINAL: NewMustang
Yeah, me too.
09-16-2015 02:11 PM
Calizic
08-28-2015 01:46 PM
