HELP PLEASE. 05 GT gone crazy (Problems)
Old Jan 6, 2007 | 01:33 AM
leviz79's Avatar
leviz79
Default HELP PLEASE. 05 GT gone crazy (Problems)
I dont know what happened but it rained over at my home and when i went to start the car the car had a hard problem turning over, when the car started the dash lights (ALL) did not illuminate and then around 4-5 sec. later the buzzer went off and the lights turned on. Everything was in normal configuration for normal driving. Everything is stock. After a few starts the car does not start, I still have power to the electricals, the radio resets itself as if someone disconnected the battery. Now the car still does not start and will not crank over sounds as if the starter broke a shaft but not cause it has a weird clicking noise when the key is turned over. I have not got it over to the dealership still under extended warrenty, just need to know if other problems exist to others or heard of, before i go.
2005 Mustang GT Coupe
Torch Red
Manufactured 11/04
5 sp.
Old Jan 6, 2007 | 02:32 AM
8cd03gro's Avatar
8cd03gro
Default RE: HELP PLEASE. 05 GT gone crazy (Problems)
unplug the battery for a half hour and hook it back up and try again...if that doesnt work-
something got water in it...someone had this exact problem before, it is some box. not the fuse box or the ecu. I will find the thread for you if i can, but it is definately water in something i wouldn't be super worried it is easily fixable.
Old Jan 6, 2007 | 02:38 AM
howarmat's Avatar
howarmat
s197 Junkie
SJB (smart junction box) located in the passeneger kick panel maybe? Read the leaking electrical problem too.
Old Jan 6, 2007 | 07:15 AM
leviz79's Avatar
leviz79
thanks for the look out, I went and put a battery charger on the battery and it was showing that it needed to be charged on the charger. Battery on stand-by (car off) read 13v. then i started the car after 30min. charge with car on read 15.4v. so i know the charging system is working but the car started up like it was brand new. I think your right about the leaking though into my car, do you think possible dying battery?
Old Jan 6, 2007 | 07:19 AM
leviz79's Avatar
leviz79
ill look into the sjb for any signs of water thanks.
love the wheels
Golfsito
Oct 6, 2015 11:02 AM
firecoyote
Sep 27, 2015 02:37 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
