Car wash question
Old Jan 9, 2007 | 12:30 PM
WhiteStallion06's Avatar
WhiteStallion06
Default RE: Car wash question
i use waffle weave towels they absorb so much more than a regular towel
Old Jan 9, 2007 | 12:32 PM
06hoss's Avatar
06hoss
California Water Blade
Old Jan 9, 2007 | 12:49 PM
wingman75's Avatar
wingman75
In the summer I used waffle weave towels. And if I found any water spots after that I used Meguires Quick Detailer and Microfiber cloths. It was getting to be a pain keeping it clean. I started to slack-off a bit (a lot). Its cold here. But now I found a car wash that washes by hand and only charges $10.00. I've been looking for a hand wash place for a long time and finally found one a mile from my house and cheap too.
davisr014's Avatar
davisr014
the Absorber and air
Old Jan 9, 2007 | 12:54 PM
wingman75's Avatar
wingman75
ORIGINAL: davisr014
Speaking of air, I've seen a motorcycle air drier being advertised on Speed channel. I guess the air is clean and warm. That could dry out those places where water collects like in the front bumper seams. Kind of expensive as I remember though.
Old Jan 9, 2007 | 01:03 PM
06GT4RAD's Avatar
06GT4RAD
After washing i mist the car with Poorboys S&W then use the Ca. Water Blade to remove most of the heavy water and follow that with two Waffle Weave Microfiber towels. No streaks no scratches no lint. I also use an air hose from my compressor to blow out all the nooks and crannies that water likes to hide in.
If you do use the CWB make sure and rinse it prior to each use and if it is dropped also rinse it off. A little common sense is all that is needed to prevent and scratches with it's use.
Richard
Old Jan 9, 2007 | 01:06 PM
davisr014's Avatar
davisr014
the front grill areais the worst. I use my air compressor to blow the water out of all of the cracks and seams.
Old Jan 9, 2007 | 01:42 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
ORIGINAL: StowesStang
ORIGINAL: RodeoFlyer
i use a synthetic chamois called The Absorber - it's under 10 bucks I think. works like a charm.
yes black is a PITA! - you should see mine today after the open track event yesterday lol
+1111 on the Absorber, best chamois Ive ever used!!!!
X's 2. I had one that lasted 4 years and still worked likechamp. Would still be using it but it got lost.
Old Jan 9, 2007 | 01:58 PM
gatkins94's Avatar
gatkins94
I'm a big fan of the "Absorber" too. Have 2 or 3 of them around the house.
Old Jan 9, 2007 | 02:11 PM
MrSandman's Avatar
MrSandman
I spray with a detail spray... and wipe/buff with a clean microfiber rag. Flawless finish every time. Black is easy if you maintain it.
ORIGINAL: jaredgoodwin
What are you guys drying your car with? Everything I have tried leaves either lint or water marks. Black cars are impossible.....
