downshifting for acceleration-steps?
Old Jan 12, 2007 | 02:17 AM
doode's Avatar
doode
Default RE: downshifting for acceleration-steps?
heh
if ur car is stock it goes something like this :
cruise in 3rd at around 2k
someone wants to race
u clutch in, blip the throttle and shift to 2nd with the clutch still in
*** this is what happens next ***
either the crappy drive by wire throttle doesnt rev at all and you are still sitting at 2k, or you poke the gas too much and you rev all the way to 4K looking like a tool
ive had my car for 6 months,8 out of 10 tries i can usually get a decent rev- match, but there are times when poking the gas does absolutely nothing !
but a tune in soon in order
Old Jan 12, 2007 | 02:48 AM
classj's Avatar
classj
Practive going from fourth to third at like 50-60 mph. Depress clutch, shift, blip, lift clutch before tach falls, and then apply gas.
If you get it right, it is more like you are feeding in the throttle as you are coming up with the clutch, and are almost to the floor with the accelerator at the same time you are up with the clutch all the way.
Old Jan 12, 2007 | 10:28 AM
I8ACHEVY's Avatar
I8ACHEVY
thanks to all...
I figured it's just a lack of practice. This is my first manual tranny car and I've got less than 3k miles on her as it is. Too used to automatics..hehehe
I'll tell you what though..it was an awesome feeling with the car screaming at 80+ in 3rd gear and realizing..."oh dang..I have 2 other gears!" ;-)
Old Jan 14, 2007 | 04:02 PM
HypromanGT's Avatar
HypromanGT
ORIGINAL: doode
heh
Ah ha!! Now I know it's not just me. I can't get over how this car can interpret the same throttle press so differently over and over again. Really annoying [:@]
Old Jan 16, 2007 | 08:53 PM
Bonkers's Avatar
Bonkers
One thing to watch when downshifting is where your revs are going to be after the shift - I've seen several instances where people tried to downshift two gears to look impressive and break the rear end completely loose at 40mph+. Easy way to do severe drivetrain damage too. If you're new to the manual transmission world take a lot of time to practice - every time you shift you change the driving dynamics of the car so make sure you learn it slow and smooth.
Old Jan 16, 2007 | 09:11 PM
xbone's Avatar
xbone
Get an automatic and let the OBD figure it out, it can think faster than any of us anyway. Pedal down go fast pedal up slow down, nice n simple.
Old Jan 16, 2007 | 09:43 PM
Feng Houzi's Avatar
Feng Houzi
ORIGINAL: xbone
Amen!
Old Jan 16, 2007 | 10:04 PM
vsop's Avatar
vsop
I rev match my down shift even during my normal driving.. Sounds great and keeps the syncros in better shape.
Heel-Toe is much easier on a race car as they have the pedlas setup for it.
Old Jan 18, 2007 | 10:41 PM
luggage's Avatar
luggage
I noticed a couple people said to keep the clutch in the whole time. This will work, but it might be hard to get it into gear if you don't speed up the input shaft.
To double-clutch, you let the clutch out while in neutral and rev the engine to match the gear you are going into (slightly higher rpm is smoother than slightly lower). This will let the engine spin up the input shaft of the tranny while you rev so that then you shift into the lower gear (clutch in for the shift) they are closer to matching speeds. This is easier on the synchros and will let the car go into gear easier (don't force the shifter on a synchromesh transmission).
Howstuffworks.com has a nice article on manual transmissions. It doesn't teach you to double-clutch, but it will explain what an input shaft, or layshaft is to those that don't know. Lots of good articles on there, actually.
Old Jan 19, 2007 | 02:12 AM
HypromanGT's Avatar
HypromanGT
ORIGINAL: luggage
Uhh...am I missing something? I thought double-clutching was a thing of the past when synchros entered the mix. I just press clutch pedal, rev to where the lower gear would be for RPMs, and take my foot off the clutch. Are you saying this isn't as easy on the transmission as double-clutching in these cars?
