Sponsored by:
Sponsored by:
Oil Change
Old 01-12-2007, 07:19 PM
ANSKY
ANSKY's Avatar
Default Oil Change
what is the best way to go...100% syn or blend?
ANSKY is offline
Old 01-12-2007, 07:47 PM
Sherwood06GT
Sherwood06GT's Avatar
Default RE: Oil Change
100% Synthetic. After a couple thousand miles or so. Redline, Royal Purple, Mobil 1, etc.
Sherwood06GT is offline
Old 01-12-2007, 08:10 PM
my77stang
my77stang's Avatar
why does nobody here use pennzoil?
my77stang is offline
Old 01-12-2007, 08:27 PM
Arwing
Arwing's Avatar
ORIGINAL: Sherwood06GT
+1 mobil 1 ftw [8D]
Arwing is offline
Old 01-12-2007, 08:35 PM
Goldenpony
Goldenpony's Avatar
5W20 Mobil 1 is your friend
Goldenpony is offline
Old 01-12-2007, 08:41 PM
Fourth Horseman
Fourth Horseman's Avatar
If you've got the time and stamina for it, this article goes into detail on oils and why the author prefers synthetics. The short version, though, is that synthetics don't have the contaminants that 'dino' oils do which can cause sludge and build-up, and a smaller portion of the total volume of synthetics are additives, hence synthetics have more actual lubricant per unit of volume than 'dino' oils.
It's an interesting read if you're curious.
Fourth Horseman is offline
Old 01-12-2007, 09:38 PM
06GT4RAD
06GT4RAD's Avatar
ORIGINAL: Fourth Horseman
Very nice informational Link! Thanks for posting that. I do however think his 12k dino oil break in period is a bit off.
Richard
06GT4RAD is offline
Old 01-12-2007, 09:40 PM
my77stang
my77stang's Avatar
still no answer for me.... seriously - is there some reason nobody uses the pennz syn? something i should know?
Old 01-13-2007, 12:33 AM
lteix
lteix's Avatar
Royal Purple [sm=groupwave.gif]
lteix is offline
Old 01-13-2007, 12:54 AM
Fourth Horseman
ORIGINAL: 06GT4RAD
Richard
I tend to agree with you. However, it's worth noting that my Marauder's 4v 4.6 V8 was still limbering up and gaining newfound power at around 12,000 miles. It was the longest period of an engine loosening up and gaining power that I've ever experienced. I started using Mobil 1 5w30 synthetic in that engine starting at 1,500 miles. Possibly the superior lubricating properties of the synthetic oil made it take longer for the engine to loosen up? I don't know, it may be unrelated, but I've decided to run 5w20 synthetic blend in my Mustang GT's engine until 9,000 miles, at which point I'll switch it over.
Quick Reply: Oil Change
