how easy to load old tune back on comp?
If I load a new tune on the computer, how easy will it be to load the old tune back up before I take it to the dealer? just wanna make sure the warranty isnt voided if i have to take it in....
RE: how easy to load old tune back on comp?
Maybetwo minutes, depending on how fast your tuner loads it. All you do isplug the SCTinto the OBDII and select return tostock after going through the main menu.
Remember you must put your stock intake back in if you are runninga different kit or you will pull a code and your car may go into failsafe.
-Jeff
-Jeff
