Door Mirror Rattle
Door Mirror Rattle
i know this has been brought up before, but has anyone found a fix for this? the dealer wont do anything because nothing is actually broke but it rattles every time you close the door. has anyone been brave enough to remove the mirrors on these? i dont wanna break anything ya know
RE: Door Mirror Rattle
Mine doesn't rattle, but it does squeak, but it doesn't do it every time so I haven't taken it in yet.....BUT
squeaks or rattles are brokens....take it back to your dealer, or another dealer, and remind them that a BUMPER-TO-BUMPER warranty means they are covering the car from one end to the other and that since you bought a car expecting to not have to listen to rattles/squeaks then they need to fix it....
I had the same problem. I took it to one dealer they said sorry can't help you. Took it to a different dealer and they put on a new mirror for me the next day. So like ponyman said try a different dealer if you can.
yeah i think its time to go to another dealer. what gets me is if its just gonna do it again, eventually we will have to fnid uor own fixes. (like the plastic trim behind the handle on the inside of the door where you put a piece of foam in there to keep it tight.... the dealer wont fix that either)
Very easy to remove mirror, just pull off door sail (traingular piece inside car), pull straight out. Disconnect wires & remove three nut & mirror is off.
Mine doesn't rattle but if it did I'd try myself before letting those butchers at the dealership do it.
