06 ebrake frozen???
Old Jan 21, 2007 | 12:20 AM
wcgman's Avatar
wcgman
Default 06 ebrake frozen???
To all the naysayers who say "do a search..." I have already googled it and done it on the forums...and come up with really jack. Someone said there was a TSB on it but I cant find it anywhere.
Left the car sitting for quite a few weeks, finally got it out but it was still cold (about 20) and let it sit for about 4 hours in the cold. Then when I got in it it wouldnt completely release. I could feel about 2" of slack in the hand brake when I would pull it before tension would occur. Then the rear wheels were still under tension (calipers were engaged somewhat) but it was cold and I was 30 miles from home. So I said F--it. I am driving it and if it blows up, it's Ford's problem. By the time I got home, it seemed to be engaging just fine. Next morning, still fine.
Please dont say "dont use it," or "use wheel chocks..." That's crap (I paid for 100% car, not 99.72%) and although I love my Fords, I will hold Ford accountable for this. However if you do have the TSB number and details I would appreciate it. Also if you have had this happen and had Ford correct it I'd like to know about that as well as ammunition if I need it...
Old Jan 21, 2007 | 12:29 AM
07AlloyGT's Avatar
07AlloyGT
Default RE: 06 ebrake frozen???
if you did a search on here and didn't find jack, you weren't looking good enough. there's an easy 5 different threads on this last week alone.
https://mustangforums.com/m_2446204/tm.htm
https://mustangforums.com/m_2576631/tm.htm
https://mustangforums.com/m_2372935/tm.htm
https://mustangforums.com/m_1044653/tm.htm
and your TSB topic:
https://mustangforums.com/m_2373410/...tm.htm#2373791
There is a TSB on this......having mine done right now. Same issue this morning.
TSB# 06-5-4
"The rear sealing boot on the e-brake cable could prematurely deteriorate which may permit water intrusion. In freezing tempurature this could bind the cable inside the casing and not allow tension to be released from the caliper."
Service procedure is to replace both rear e-brake cables.
Old Jan 21, 2007 | 12:42 AM
edgespeeder06's Avatar
edgespeeder06
dude i feel ur pain, that **** happen to me once, but i backed out and it cleared, but if it happens again, im having it carried to ford to have the ebrake cables and whatever else fixed
Old Jan 21, 2007 | 12:43 AM
geofcar's Avatar
geofcar
yep, had the same problem this week with my '05. Took it in to the dealer and had the ebrake cable replaced. as good as new now.
Old Jan 21, 2007 | 02:04 AM
Goldenpony's Avatar
Goldenpony
Yup, happened to my '06 GT 'vert. Trip to dealer for 2 new e-brake cables under warranty. OK now.
Old Jan 21, 2007 | 02:22 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Thank you...oh and I was one of the naysayers!
ORIGINAL: 07AlloyGT
and your TSB topic:
TSB# 06-5-4
Old Jan 21, 2007 | 11:47 AM
wcgman's Avatar
wcgman
Thanks for your help and the links. Guess I was searching wrong She'll be going into Ford for a little TLC
Old Jan 29, 2007 | 09:06 PM
edgespeeder06
https://mustangforums.com/m_2614714/mpage_1/key_/tm.htm yup happened to me too, but parts are on back order, anyone else had to face that?
Old Jan 30, 2007 | 02:28 AM
oldyeller's Avatar
oldyeller
had mine fixed friday. took 1 month for the dealer to get parts.seems the cables went thru a 2nd engineering phase.i now have the rev 3 version lol soon they will get it right.
cyclop5
Oct 3, 2015 09:21 PM
Scooterman
Mar 18, 2006 01:58 AM
swordseven
May 27, 2005 12:34 PM
87FiveO
May 13, 2005 03:44 AM
goldlifter
Mar 10, 2005 10:10 PM
