Specific Wheel Question
Old Jan 21, 2007 | 12:53 PM
Tracedaddy's Avatar
Tracedaddy
Default Specific Wheel Question
Will this fit.
19" Staggered Size: Two:19x8.5" (30 or 35mm offset)and Two:19x9.5" (45mm offset)Ver-One Wheels - Hypersilver/Polished Lip - Lug Pattern: 5x114.3 (or 5x4.5) To fit many Rear Wheel Drive 5 lug pattern cars, ie: Lexus SC, GS, LS, 300 / 400 / 430 models - Infiniti M35, M45, Q45, G35 Sedan,Mazda RX7, RX8, Toyota Supra, 05-07 Ford Mustangs and manyother vehicles with 5x114.3 Lug Pattern...
Pleasedouble check fittment with tire/wheel shop or a knowledgable Mechanic "Before Bidding".
I know it says 05-07 Ford Mustangs, but the "Please Double-Check" comment has me wondering.
Anyone smarter than me know?
Thanks.
Old Jan 22, 2007 | 11:13 AM
Tracedaddy's Avatar
Tracedaddy
Default RE: Specific Wheel Question
No one?
Old Jan 22, 2007 | 12:14 PM
drbobvs's Avatar
drbobvs
Uh, those front ones will definitely fit. For the rear, this is one instance where you need to check your stock backspacing. Since the offset for those is 45mm the wheel will stick INTO and OUT OF the car by 3/4'. So if you have at least 3/4' clearance behind your stock rear wheels to the shock, wheel well, control arm or any other thing back there you will be fine.
Old Jan 22, 2007 | 12:17 PM
Tracedaddy's Avatar
Tracedaddy
Super. Thanks for the info.
Old Jan 22, 2007 | 12:34 PM
swieduwi's Avatar
swieduwi
the Stock S197 where has a +36mm offset, the rims I have now are the DD Bullet18x9 and they are a +45mm offset
[IMG]local://upfiles/18759/C362F56503184577B3C67A5662CEDF3B.jpg[/IMG]
[IMG]local://upfiles/18759/3462F36B314D441E8C2AC9CE2A98BBEC.jpg[/IMG]
Old Jan 22, 2007 | 12:38 PM
Tracedaddy's Avatar
Tracedaddy
Then it appears all the guess work is out then. Thanks to you tooo.
And nice car. [sm=smiley14.gif]
Tivo304
Aug 28, 2023 12:19 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
