What did they do for you gas tank?
RE: What did they do for you gas tank?
ORIGINAL: algregory
'05 Screaming Yellow GT here.
Had problems at the beginning. Don't think I ever attempt to let the nozzle hang in the filler. I just hold the handle at somewhere around three o'clock and hold it at pretty fast fill rate. Haven't really had a problem filling in some time, except for the fact I can't do anything but hold the nozzle.
I also always check the "Gallons Used" before I start filling. My car is more often than not full at .5 gallons +/- of the "Gallons Used" indicated. Once in awhile since I INSIST on topping off I get a wee spill and I pull my Meguiar's and cloth and clean it up. Keep some in the trunk all the time.
Here is a link to how to fix the problem so bring this to the dealership and show them or you can try yourself but this works
http://ratstangrestoration.com/05_mustang_tank.htm
doesnt the designers check for simple problems like this? every day i see more and more problems inherent with a car that is (and should be) so spectacular.
grrrrrrrrr.........
grrrrrrrrr.........
The problem with this issue is that it depends on the pump you fill the car up at. Some gas stations it works OK, and others it dones't. What is Ford supposed to do? Check fill-ups at 50 different gas stations?
The problem is that something about the gas tank fill/vent piping makes the gas pump think the tank is full when it's really not. So, gas stations that have more sensitive pumps are more prone to this problem than others. Also, the problem is more likely to occur if you fill the gas quickly.
Anyway, my car has this problem. I just put the gas nozzle at the 3 o clock position and it fills up perfectly every time, even at max flow. Problem solved.
I have tried to turn the nozzle up-side down and it still takes a little more but shuts off.... its that spring thats on the end of the nozzle I think... it doesnt let the filler go completely or even halfway in.... the 2 gas stations that I use, dont have a spring on the nozzle, so it lets the filler nozzle go completely inside. I dont know if Ford put in a device so that people cant spihon gas from the car? im heading to my dealer in 1 hour and ill see what they say... oh and i live on an island where there are not alot of gas stations where I live, so for me i consider it a big concern. Unlike the mainland, i dont have a gas station around the every corner... just 25 miles inbetween...
Other Ford vehicles can fill up at any gas station with no problem, why cant my car be so easy?
EDIT: thanks BillyJo for that page about the box.... ill tell my dealer about that too..
ORIGINAL: CrazyAl
ORIGINAL: Skoshi42
Now what Ford needs to do at this point is come up with a good fix for it and then retrofit the cars. Everyone makes mistakes--the real issue is how do they deal with them afterwards.
I don't know how everyone can just deal with holding the nozzle a certain way lol. It STILL is a pain to do it that way. It's a new car there should be ZERO problems. Im still under warranty, so they better be doing something.
